Blaster213
Aug 17, 2020Aspirant
XR700 Dumo OS 3.0 beta
Where can i get the update I signed up 2 months ago
- Aug 18, 2020As above, it also isn't available for the XR700 just yet.
Aug 18, 2020Guru - Experienced User
Signing up doesn't mean that you'll get into the test. It just gives you a chance.
If you don't get into the 3.0 beta test, then you'd need to wait on the public release.
Netduma-Fraser
Aug 18, 2020NetDuma Partner
- Blaster213Aug 18, 2020Aspirant
thanks
