MICKYMAC
Aug 18, 2020Follower
XR700 External USB disconnect wifi
Hi All,
Bit of an issue i've had I connected a USb 3 external HDD to one of the usb ports on the side of the XR700 so I can access it via the network at home and from office. Problem I have is the wifi drops out (turns off completely) when the drive is connected. The moment I disconnect the drive from the port the wifi starts flashing and works again.
Any solutions to this problem? I'm currently running fimrware version 1.0.1.20
1 Reply
- Netduma-FraserNetDuma Partner
Is the drive formatted to the correct file type? https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
Also is the drive from one of the known compatible drives? Check XR500 and R9000 for the drives that would work with the XR700. https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
