thatmyles
Jan 05, 2021Tutor
XR700 Firmware Version 1.0.1.36 Issues
I'm having Wi-Fi stability issues on the lastest firmware on my XR700. Downgrading to v1.0.1.34 fixes these issues. I noticed this first with my TP-Link smart switch when it refused to connect to the...
Netduma-Fraser
Jan 05, 2021NetDuma Partner
That's odd because .36 only included security fixes so nothing to do with WiFi. Did you do a factory reset after upgrading? It is generally recommended to do so as it could bring over old low level code from the previous version which could interact and cause issues on the new version.
- thatmylesJan 05, 2021Tutor
I did do a factory reset and multiple reboots. The issue persisted. I'll try another upgrade and round of testing again this week.
- Netduma-FraserJan 05, 2021NetDuma PartnerHave you tried the beta firmware to see if it is an issue there also? https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
I have not. I'll give the new 3.0 beta a try first. Thanks
