TimboSlice1967
Dec 18, 2022Aspirant
XR700 Firmware
So "upgraded" my XR500 after suffering serious lag issues while playing COD, to an XR700. Updated to the "latest" beta firmware (1.0.1.34_DUMAOS3.0_6) nearly two years ago. Still suffering with horren...
TimboSlice1967
Jan 03, 2023Aspirant
Jan 03, 2023Guru - Experienced User
Do you have any wifi neighbors near by?
I would try changing channels to 1 on 2.4Ghz and 40 or 149 and 5Ghz.
I would disable the 60Ghz SSID broadcast as I presume you may not be using it.
Set 20/40Mhz coexistence to 40Mhz.
- TimboSlice1967Jan 04, 2023Aspirant
Will try that and feedback later. When you say set coexistence to 40Mhz, do you just mean disable 20/40Mhz coexistence?
Thanks
Tim
- FURRYe38Jan 04, 2023Guru - Experienced User
Yes.
- TimboSlice1967Jan 20, 2023Aspirant
OK... so here is the update. I have followed all of the above advice, and over the last few weeks have continually tweaked different settings to try and solve my issues of poor COD play, especially when devices in the house are streaming, and also my mobile phone connection being intermittently slow. I've tried adjusting the sliders, adjusting QoS, Geo filtering, MTU settings... everything. I changed the cheap Aztec switch for a Netgear gigabyte switch. My ISP is fine... there is not a setting I haven't tried. Upshot is, I called in an IT guy of mine and we took out the XR700 and installed a temporary mid range Draytek router. The results were instant. I played 10 games of COD and topped every game with twice as many kills as everyone else, and QoS wasn't even enabled! this test was undertaken during a busy evening time period, where an ISP would normally throttle the connection, and with 6 devices in the house streaming YouTube simultaneously over ethernet and WiFi. The Draytec had to go back a few days later as it was for testing only, and I have now uninstalled the XR700, and set my ISP router back to router mode from modem mode. Gaming for a day now, and there is not much real difference from when the XR700 was there. So... after much time and money wasted, and with the XR700 STILL being on a Beta version of Duma3.0 I have decided enough is enough and will be selling it, as it clearly does not do what it is supposed to... I don't think it was a faulty unit, as I upgraded to it from an XR500 that had similar issues.
- Netduma-FraserJan 20, 2023NetDuma PartnerSorry to hear that, I'm sure it's something we could have resolved or something that would have improved when the next update is available but I totally understand your frustration.
- FURRYe38Jan 20, 2023Guru - Experienced User
Would be nice to know if the ISP modem had been bridged or not considering it's a gateway modem and could cause problems.
What Region are you located?
