user12a
Jul 02, 2021Star
XR700 FW version 1.0.1.34, 36, 38 missing Telnet Enable ?
It seems the xr700 FW versions 1.0.1.34, 36, 38 all have the Telnet Enable missing in the debug.htm page. Only back in 1.0.1.20 the Telnet Enable option is available. Can we have the Telnet re-e...
user12a
Jul 02, 2021Star
Here is the Telnet Enable on FW 1.0.1.20 debug image :
Netduma-Fraser
Jul 02, 2021NetDuma Partner
Netgear decided to remove this functionality so I'm not sure they will reimplement it. What issues have you had that you've fixed using telnet?
- user12aJul 02, 2021Star
There are limitless number of things one can do on the Linux kernel of this powerful quad core Arm7 processor. You can install Adguard Home, DNS tools, among many things on the XR700 router that people have implemented on the R9000 which has identical HW. One key item is the ability to erase corrupted nvram through Telnet when the Netgear FW corrupts the router, very common.
Since this router was sold with the Telnet option available, Netgear cannot just take it away without a very valid reason. Very bad business for those who have invested on this router for its options. Please have Netgear add it back. Otherwise people who want to use Telnet are stuck on version 20 FW.
- Netduma-FraserJul 03, 2021NetDuma PartnerI understand why you want it but they do not advertise Telnet as a feature, that's why it is purposefully hidden away on the debug page - it's not meant for wide use. It's their side of the firmware we can't make them re-add it.
