Haveck
Mar 24, 2019Guide
XR700 Geo-FIlter for PC not working
So is it me or does Geo-Filter for PC gamers not work. I'ved tried a few games like Overwatch and Killing Floor 2 (Browse Servers) and will get a blimp for a second then everything disappears. Is there something I need to allow on my internal Windows firewall for this stuff to get picked up? whats the deal.
Also very limited support for games in general like Apex Legends, Warframe, HoTS, Monster Hunter World, etc.
Yes, switching my PC to Playstation seemed to perform better. Yeah I am guessing since there are dedicated servers it will only give me that info and not other players connected to it. Same as Peer-to-Peer will give me the player information for games like Vermintide 2 (untested).
Also noticing that when swapped to Playstation it appears to monitor everything, which is kinda cool i suppose. Shows me Discord location, etc.
- Netduma-FraserNetDuma PartnerIf you're using a server browser for a PC game then you don't need to use the Geo-Filter as well as you can just select the closest/lowest ping server, so disable it otherwise it might block them.
Apex Legends is a source engine game so you would select that. We need to update support for more PC games. You can change your PC to a console in device manager and re-add it to the Geo-Filter, that will work.- HaveckGuide
I only used Server Browser for KF2, and even with that it only shows people/servers for a second. Overwatch is complete Matchmaking and only showed server info when I first launched the game.
So what your saying is that it doesn't support PC detection therefore I have to change it to PS4 in order to trick it?
- HaveckGuide
Changed it to Xbox. Found some info before even clicking play...not sure why its doing that. Once I join a match all information disappears.
