Haveck
Mar 24, 2019Guide
XR700 Geo-FIlter for PC not working
So is it me or does Geo-Filter for PC gamers not work. I'ved tried a few games like Overwatch and Killing Floor 2 (Browse Servers) and will get a blimp for a second then everything disappears. Is t...
- Mar 26, 2019
Yes, switching my PC to Playstation seemed to perform better. Yeah I am guessing since there are dedicated servers it will only give me that info and not other players connected to it. Same as Peer-to-Peer will give me the player information for games like Vermintide 2 (untested).
Also noticing that when swapped to Playstation it appears to monitor everything, which is kinda cool i suppose. Shows me Discord location, etc.
Haveck
Mar 24, 2019Guide
Changed it to Xbox. Found some info before even clicking play...not sure why its doing that. Once I join a match all information disappears.
Netduma-Fraser
Mar 26, 2019NetDuma Partner
Overwatch should work just fine, PC does work for some games but an easy way for users to have that functionality for other games is to switch it to a console.
It'll be showing information from the game client e.g. Steam, Origin, Battle.net. Are you fully zoomed out on the map?
- HaveckMar 26, 2019Guide
Anything on PC seems intermittent. Overwatch would work briefly and all icons on the global map would disappear, same tend to happen when I switched to Xbox.
I switched to PlayStation and information tends to stay, however doesn't give player information as I thought, only gives server connected to in the form of a player icon for Overwatch and Apex.
Yes, map fully zoomed out during all these trials.
- Netduma-FraserMar 26, 2019NetDuma PartnerSo it does show an icon to indicate the server when in game then? Most games that connect to a dedicated server will only show the server on the map as you don't have direct connections to players so can't be shown.
