xTEKNEKx
Dec 20, 2019Tutor
XR700 geofilter not working
Just bought the XR700, had it for about a week now, love how much you can customize everything, but the main reason I bought it, (Geofilter)seems it’s not working. I have my Xbox one set to the geofil...
Netduma_Alex
Dec 20, 2019NetDuma Partner
I'm glad you're (mostly) enjoying your XR700!
So what does the map look like when you get connected to a distant server? Which icon is displayed on the map?
xTEKNEKx
Dec 20, 2019Tutor
It’s could be a dedicated or peer I connect to both from Texas to Far East cost. I know I’m connected to that server because It’s the biggest icon server during the game. I’ve also use auto ping and sure enough it’s the server.
- Netduma_AlexDec 20, 2019NetDuma Partner
Would it be a hassle for you to provide a screenshot?
- xTEKNEKxDec 20, 2019TutorIt’s says I can’t because it does not have a valid extension?
- xTEKNEKxDec 22, 2019TutorSo I’ve removed my Xbox from geofilter, hard shutdown my Xbox, flush the cloud, reboot my router, add my Xbox back to geofilter, Filtering and strict mode enabled, set the location(Hawaii) set profile(call of duty) geofilter expands to California, powered up my console, Started my game, it still puts me in servers outside of my geofilter? I don’t get it. I must be doing something wrong? Also the home server with the solid white circle around the square says it’s in Europe wtf! Wouldn’t it be in California or at least the USA. I field out the small form regarding this issue, giving the servers ID and my location. Idk man I feel like the $500 router might not be worth the money or stress trying to optimize the perfect connection for gaming. Any help NETGEAR team?
- yurarndMar 22, 2020Tutor
the same problem and on my xr300 everything is correctly configured but connects outside the circle, although it should not do this , the latest firmware is installed , but on the stock firmware the geofilter works normally, I had xr500 before there was no such problem
- Netduma-FraserMar 22, 2020NetDuma Partneryurarnd as you've made a separate topic for your issue lets keep it in there so it's easy to track.
