xTEKNEKx
Dec 20, 2019Tutor
XR700 geofilter not working
Just bought the XR700, had it for about a week now, love how much you can customize everything, but the main reason I bought it, (Geofilter)seems it’s not working. I have my Xbox one set to the geofil...
yurarnd
Mar 22, 2020Tutor
the same problem and on my xr300 everything is correctly configured but connects outside the circle, although it should not do this, the latest firmware is installed, but on the stock firmware the geofilter works normally, I had xr500 before there was no such problem. p.s. ping assistant is disabled i play on ps4 pro
