xTEKNEKx
Dec 20, 2019Tutor
XR700 geofilter not working
Just bought the XR700, had it for about a week now, love how much you can customize everything, but the main reason I bought it, (Geofilter)seems it’s not working. I have my Xbox one set to the geofil...
Netduma_Alex
Dec 20, 2019NetDuma Partner
Would it be a hassle for you to provide a screenshot?
yurarnd
Mar 22, 2020Tutor
the same problem and on my xr300 everything is correctly configured but connects outside the circle, although it should not do this , the latest firmware is installed , but on the stock firmware the geofilter works normally, I had xr500 before there was no such problem
- Netduma-FraserMar 22, 2020NetDuma Partneryurarnd as you've made a separate topic for your issue lets keep it in there so it's easy to track.
