PCLLC-JFenn
Apr 05, 2019Tutor
XR700 Glitching games during gameplay
So I bought this router about 3 days ago. First to get to the admin page (192.168.1.1) took a very uncomfortably long time and makes you wonder if you have a bad unit. Once the setup wizard actuall...
Apr 11, 2019Guru - Experienced User
To go from PAR NAT to Full Cone NAT you have to set NAT Filter to OPEN on the router.
PCLLC-JFenn wrote:
When getting into the router's settings, when selecting NAT type on both IPv4 & 6 as open, I'm still getting test results as it being a PAR Nat - should be a full cone on open NAT.
PCLLC-JFenn
Apr 11, 2019Tutor
Currently I'm on the .08 FW since .10 seemed very sluggish. No ISP modem using a CM600. NAT is set to OPEN which is why I thought PAR was abnormal but NG FW on the 8000, 8000p and 9000 also have this issue. Also after hooking up the TP-Link 8-port gigabit switch to the XR700 the lag came back in Overwatch. I took it out of the picture and things are smoothe again.
