PCLLC-JFenn
Apr 05, 2019Tutor
XR700 Glitching games during gameplay
So I bought this router about 3 days ago. First to get to the admin page (192.168.1.1) took a very uncomfortably long time and makes you wonder if you have a bad unit. Once the setup wizard actuall...
Jun 25, 2019Guru - Experienced User
I how have a XR700 to play with for a bit.
I can confirm that NAT FIlter is not working correctly when set to OPEN:
XR700 with both shipping FW and latest v.10 loaded. Full cone is not showing when NAT Filter is set to OPEN.
Shipping FW 1.0.0.20
XR700: NAT Filter set to Secure
Address Restricted NAT: http://nattest.net.in.tum.de/individualResult.php?hash=0b26c9adccd38a9bcf7eb5f9e13f9c33
XR700: NAT Filter set to Open
Test 1 Address Restricted NAT: http://nattest.net.in.tum.de/individualResult.php?hash=cf61e881b487ee2fe40629446eae95b6
Test 2 Address Restricted NAT: http://nattest.net.in.tum.de/individualResult.php?hash=888362e460a1a63ec3e6c7fa52740d60
Updated FW with NAT Filter set to OPEN: v1.0.1.10
Address Restricted NAT reported with Windows 7 and OSX: http://nattest.net.in.tum.de/individualResult.php?hash=9e3b46f4c2b36f38f76b3a2b25adce19
Factory reset and NAT Filter set to OPEN:
Address Restricted NAT reported with Windows 7 and OSX http://nattest.net.in.tum.de/individualResult.php?hash=0ef0dd7bc2d5bbed451deece53fa8a61
My XR450 doesn't have this problem and reports FULL CONE NAT when NAT Filter set to OPEN.
Netduma-Fraser
Jun 25, 2019NetDuma Partner
Thanks for the heads up, I’ll pass this onto Netgear.
- FURRYe38Jun 25, 2019Guru - Experienced User
Thank you much.
- PCLLC-JFennJun 25, 2019Tutor
No need. I've spoken with the L2 team about this issue and it was resolved in the XR700 V1.0.1.10 firmware. I can say with confidence that selecting open NAT on this version does report a full cone during testing. I still feel as the .08 firmware seems a bit snappier in the gui where the .10 variant seems to be sluggish (especially on a router with a 1.7Ghz quad-core) but it does work as intended with all features. Only place I've noticed an issue (and not really an issue if you don't have the topography) is when I connected the router direct to a switch, then piggy-backed the rest of my switches off that switch to various wired devices. Instead I run wire to the individual switches where the devices are plugged in. Good thing we have 6 LAN ports as I have 6 switches in various points in the house. Anyway, keep up the good work boys.
Interesting, I have not been able to get FULL CONE NAT with mine, with shipping for v10 FW.
What versions of browser and Java are you using to test for NAT?
I tried a Windows 7 laptop and a Mac Book Pro 2008. Both are not reporting FULL CONE NAT.
What modem is your XR700 connected too?
PCLLC-JFenn wrote:No need. I've spoken with the L2 team about this issue and it was resolved in the XR700 V1.0.1.10 firmware. I can say with confidence that selecting open NAT on this version does report a full cone during testing. I still feel as the .08 firmware seems a bit snappier in the gui where the .10 variant seems to be sluggish (especially on a router with a 1.7Ghz quad-core) but it does work as intended with all features. Only place I've noticed an issue (and not really an issue if you don't have the topography) is when I connected the router direct to a switch, then piggy-backed the rest of my switches off that switch to various wired devices. Instead I run wire to the individual switches where the devices are plugged in. Good thing we have 6 LAN ports as I have 6 switches in various points in the house. Anyway, keep up the good work boys.
