dahliamo
Jul 25, 2020Aspirant
XR700 Hybrid VPN not working on Xbox
When i first set up the VPN to my router using HMA, it was working fine and was showing a different IP. Now when connected hardwired to my router, the xbox isnt showing a VPN IP. Every other device i...
dahliamo
Jul 26, 2020Aspirant
I check on whatsmyip.org using microsoft edge on my xbox. When i first used the router, my xbox was showing a VPN IP. Now suddendly it wont mask the IP.
Netduma-Fraser
Jul 26, 2020NetDuma Partner
How have you added the console to the Hybrid VPN, could you provide a screenshot please?
- dahliamoJul 27, 2020Aspirant
so i have the xbox connected via ethernet. if i add the console while it is connected via ethernet, it will give me a double NAT type. It should automatically be connected to the hybrid vpn if connected via ethernet.
- Netduma-FraserJul 28, 2020NetDuma PartnerSorry should have been more clear, could you take a screenshot of how you've added it to the Hybrid VPN feature - the right panel?
