Gardone8876
Feb 04, 2019Guide
XR700 igmp snooping with gs810emx
I have a XR700 connected to a GS810EMX switch. Does "IGMP Snooping Static Router Port" need to be set on the GS810EMX? Does the XR700 send out igmp queries periodicly? I have unchecked "Disable igmp p...
- Feb 04, 2019
Does the user manual have any information regarding this feature? I would presume if you don't have a need for IGMP protocols, then it could be disabled.
I would ask for support on the GS810 switch to see if that should be configured only or if both need to be configured.
Gardone8876 wrote:
I have a XR700 connected to a GS810EMX switch. Does "IGMP Snooping Static Router Port" need to be set on the GS810EMX? Does the XR700 send out igmp queries periodicly? I have unchecked "Disable igmp proxying" on the XR700. Does the XR700 support igmp snooping?
Feb 04, 2019Guru - Experienced User
- Gardone8876Feb 04, 2019GuideThanks I'll make a new thread to ask for help with the gs810emx
- FURRYe38Feb 04, 2019Guru - Experienced User
:smileywink:
