Jun 28, 2019Guru - Experienced User
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test. Seems like the HW NAT accelleration or Cut-Through that should be work...
-Donovan-
Jun 28, 2019Luminary
Nice job FURRYe38!
I report earlier this issue and I though I was the only who had this WAN Port not reaching the Gigabit speed on my XR700. Thank you for validating this problem with your WAN to LAN test!
- Netduma-FraserJun 29, 2019NetDuma PartnerHow were the speed tests done? If you used other platforms did they report the same?
Is PPPoE/VLAN/IPv6 being used?
