Jun 28, 2019Guru - Experienced User
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test. Seems like the HW NAT accelleration or Cut-Through that should be work...
Netduma-Fraser
Jun 29, 2019NetDuma Partner
As you are able to do that test would you be able to repeat it using iPerf? That is what we (Netduma) use to test in the office.
Jun 29, 2019Guru - Experienced User
I would presume results would be the same. I've tested with this more simplified program with other routers to compare.
Does NetDuma see same or similar speed results in there testing with the XR700?
iPerf Results:
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 34.0 MBytes 285 Mbits/sec
[ 5] 1.00-2.00 sec 36.0 MBytes 301 Mbits/sec
[ 5] 2.00-3.01 sec 34.8 MBytes 291 Mbits/sec
[ 5] 3.01-4.01 sec 36.5 MBytes 305 Mbits/sec
[ 5] 4.01-5.01 sec 34.8 MBytes 291 Mbits/sec
[ 5] 5.01-6.01 sec 28.1 MBytes 236 Mbits/sec
[ 5] 6.01-7.01 sec 36.6 MBytes 307 Mbits/sec
[ 5] 7.01-8.01 sec 28.8 MBytes 240 Mbits/sec
[ 5] 8.01-9.02 sec 36.9 MBytes 308 Mbits/sec
[ 5] 9.02-10.02 sec 26.9 MBytes 225 Mbits/sec
[ 5] 10.02-11.02 sec 33.4 MBytes 279 Mbits/sec
[ 5] 11.02-12.02 sec 34.6 MBytes 290 Mbits/sec
[ 5] 12.02-13.03 sec 35.9 MBytes 300 Mbits/sec
[ 5] 13.03-14.03 sec 34.8 MBytes 291 Mbits/sec
[ 5] 14.03-15.06 sec 35.9 MBytes 292 Mbits/sec
[ 5] 15.06-16.06 sec 35.1 MBytes 294 Mbits/sec
[ 5] 16.06-17.11 sec 28.5 MBytes 229 Mbits/sec
[ 5] 17.11-18.11 sec 35.4 MBytes 295 Mbits/sec
[ 5] 18.11-19.12 sec 37.0 MBytes 309 Mbits/sec
Sent
[ 5] 0.00-20.00 sec 676 MBytes 283 Mbits/sec
Received
iperf Done.
Done.
Speed seems all over place. Still nothing much over 300Mbps
