Jun 28, 2019Guru - Experienced User
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test. Seems like the HW NAT accelleration or Cut-Through that should be work...
Jun 29, 2019Guru - Experienced User
4 Parallel Streams set:
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[ 6] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[ 7] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[ 8] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[SUM] 0.00-1.20 sec 7.50 MBytes 52.5 Mbits/sec
[ 5] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[ 6] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[ 7] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[ 8] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[SUM] 1.20-2.20 sec 7.50 MBytes 62.6 Mbits/sec
[ 5] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[ 6] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[ 7] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[ 8] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[SUM] 2.20-3.22 sec 7.50 MBytes 61.9 Mbits/sec
[ 5] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 6] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 7] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 8] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[SUM] 3.22-4.23 sec 7.50 MBytes 62.5 Mbits/sec
[ 5] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 6] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 7] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 8] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[SUM] 4.23-5.23 sec 7.50 MBytes 62.5 Mbits/sec
[ 5] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[ 6] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[ 7] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[ 8] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[SUM] 5.23-6.24 sec 7.50 MBytes 62.2 Mbits/sec
[ 5] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[ 6] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[ 7] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[ 8] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[SUM] 6.24-7.27 sec 7.50 MBytes 61.5 Mbits/sec
[ 5] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[ 6] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[ 7] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[ 8] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[SUM] 7.27-8.27 sec 7.50 MBytes 62.9 Mbits/sec
[ 5] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[ 6] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[ 7] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[ 8] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[SUM] 8.27-9.28 sec 7.50 MBytes 62.3 Mbits/sec
[ 5] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[ 6] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[ 7] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[ 8] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[SUM] 9.28-10.29 sec 7.50 MBytes 62.3 Mbits/sec
[ 5] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[ 6] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[ 7] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[ 8] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[SUM] 10.29-11.46 sec 7.50 MBytes 53.7 Mbits/sec
[ 5] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[ 6] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[ 7] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[ 8] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[SUM] 11.46-12.47 sec 7.50 MBytes 62.4 Mbits/sec
[ 5] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[ 6] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[ 7] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[ 8] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[SUM] 12.47-13.47 sec 7.50 MBytes 62.4 Mbits/sec
[ 5] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[ 6] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[ 7] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[ 8] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[SUM] 13.47-14.48 sec 7.50 MBytes 62.4 Mbits/sec
[ 5] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[ 6] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[ 7] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[ 8] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[SUM] 14.48-15.50 sec 7.50 MBytes 61.8 Mbits/sec
[ 5] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[ 6] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[ 7] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[ 8] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[SUM] 15.50-16.68 sec 7.50 MBytes 53.5 Mbits/sec
[ 5] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[ 6] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[ 7] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[ 8] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[SUM] 16.68-17.85 sec 7.50 MBytes 53.6 Mbits/sec
[ 5] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[ 6] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[ 7] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[ 8] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[SUM] 17.85-18.99 sec 7.50 MBytes 55.2 Mbits/sec
[ 5] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[ 6] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[ 7] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[ 8] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[SUM] 18.99-20.07 sec 7.50 MBytes 58.5 Mbits/sec
Sent
[ 5] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Sent
[ 6] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Sent
[ 7] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Sent
[ 8] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Total sent
[SUM] 0.00-20.07 sec 392 MBytes 164 Mbits/sec
Total received
iperf Done.
Done.
