Jun 28, 2019Guru - Experienced User
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test. Seems like the HW NAT accelleration or Cut-Through that should be work...
Jun 29, 2019Guru - Experienced User
4 Parallel Streams set:
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[ 6] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[ 7] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[ 8] 0.00-1.20 sec 1.88 MBytes 13.1 Mbits/sec
[SUM] 0.00-1.20 sec 7.50 MBytes 52.5 Mbits/sec
[ 5] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[ 6] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[ 7] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[ 8] 1.20-2.20 sec 7.00 MBytes 58.4 Mbits/sec
[SUM] 1.20-2.20 sec 7.50 MBytes 62.6 Mbits/sec
[ 5] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[ 6] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[ 7] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[ 8] 2.20-3.22 sec 6.88 MBytes 56.7 Mbits/sec
[SUM] 2.20-3.22 sec 7.50 MBytes 61.9 Mbits/sec
[ 5] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 6] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 7] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 8] 3.22-4.23 sec 4.50 MBytes 37.5 Mbits/sec
[SUM] 3.22-4.23 sec 7.50 MBytes 62.5 Mbits/sec
[ 5] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 6] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 7] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[ 8] 4.23-5.23 sec 4.50 MBytes 37.5 Mbits/sec
[SUM] 4.23-5.23 sec 7.50 MBytes 62.5 Mbits/sec
[ 5] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[ 6] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[ 7] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[ 8] 5.23-6.24 sec 4.88 MBytes 40.5 Mbits/sec
[SUM] 5.23-6.24 sec 7.50 MBytes 62.2 Mbits/sec
[ 5] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[ 6] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[ 7] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[ 8] 6.24-7.27 sec 7.00 MBytes 57.4 Mbits/sec
[SUM] 6.24-7.27 sec 7.50 MBytes 61.5 Mbits/sec
[ 5] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[ 6] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[ 7] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[ 8] 7.27-8.27 sec 6.75 MBytes 56.6 Mbits/sec
[SUM] 7.27-8.27 sec 7.50 MBytes 62.9 Mbits/sec
[ 5] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[ 6] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[ 7] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[ 8] 8.27-9.28 sec 4.88 MBytes 40.5 Mbits/sec
[SUM] 8.27-9.28 sec 7.50 MBytes 62.3 Mbits/sec
[ 5] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[ 6] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[ 7] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[ 8] 9.28-10.29 sec 5.00 MBytes 41.5 Mbits/sec
[SUM] 9.28-10.29 sec 7.50 MBytes 62.3 Mbits/sec
[ 5] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[ 6] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[ 7] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[ 8] 10.29-11.46 sec 4.62 MBytes 33.1 Mbits/sec
[SUM] 10.29-11.46 sec 7.50 MBytes 53.7 Mbits/sec
[ 5] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[ 6] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[ 7] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[ 8] 11.46-12.47 sec 2.38 MBytes 19.8 Mbits/sec
[SUM] 11.46-12.47 sec 7.50 MBytes 62.4 Mbits/sec
[ 5] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[ 6] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[ 7] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[ 8] 12.47-13.47 sec 4.25 MBytes 35.4 Mbits/sec
[SUM] 12.47-13.47 sec 7.50 MBytes 62.4 Mbits/sec
[ 5] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[ 6] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[ 7] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[ 8] 13.47-14.48 sec 8.25 MBytes 68.6 Mbits/sec
[SUM] 13.47-14.48 sec 7.50 MBytes 62.4 Mbits/sec
[ 5] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[ 6] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[ 7] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[ 8] 14.48-15.50 sec 6.25 MBytes 51.5 Mbits/sec
[SUM] 14.48-15.50 sec 7.50 MBytes 61.8 Mbits/sec
[ 5] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[ 6] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[ 7] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[ 8] 15.50-16.68 sec 4.25 MBytes 30.3 Mbits/sec
[SUM] 15.50-16.68 sec 7.50 MBytes 53.5 Mbits/sec
[ 5] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[ 6] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[ 7] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[ 8] 16.68-17.85 sec 4.62 MBytes 33.0 Mbits/sec
[SUM] 16.68-17.85 sec 7.50 MBytes 53.6 Mbits/sec
[ 5] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[ 6] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[ 7] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[ 8] 17.85-18.99 sec 2.38 MBytes 17.5 Mbits/sec
[SUM] 17.85-18.99 sec 7.50 MBytes 55.2 Mbits/sec
[ 5] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[ 6] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[ 7] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[ 8] 18.99-20.07 sec 7.75 MBytes 60.5 Mbits/sec
[SUM] 18.99-20.07 sec 7.50 MBytes 58.5 Mbits/sec
Sent
[ 5] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Sent
[ 6] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Sent
[ 7] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Sent
[ 8] 0.00-20.07 sec 98.0 MBytes 41.0 Mbits/sec
Received
Total sent
[SUM] 0.00-20.07 sec 392 MBytes 164 Mbits/sec
Total received
iperf Done.
Done.
Netduma-Fraser
Jun 29, 2019NetDuma Partner
That's odd, are your ethernet cables compatible with gigabit?
Put 1000/1000 in QoS and set to never and try again. Then also disable QoS completely in Anti-BB settings and try that.
- FURRYe38Jun 29, 2019Guru - Experienced User
I run only CAT6 LAN cables. Same cables that tested the XR450 and other routers.
Those settings are default already after doing a factory reset. We expect routers to handle 900Mbps +- at factory defaults.
1 Stream:
[ 5] 0.00-1.00 sec 34.6 MBytes 290 Mbits/sec
[ 5] 1.00-2.00 sec 36.8 MBytes 308 Mbits/sec
[ 5] 2.00-3.00 sec 37.0 MBytes 310 Mbits/sec
[ 5] 3.00-4.01 sec 37.5 MBytes 314 Mbits/sec
[ 5] 4.01-5.01 sec 37.5 MBytes 314 Mbits/sec
[ 5] 5.01-6.01 sec 37.4 MBytes 313 Mbits/sec
[ 5] 6.01-7.01 sec 29.8 MBytes 249 Mbits/sec
[ 5] 7.01-8.01 sec 37.5 MBytes 314 Mbits/sec
[ 5] 8.01-9.02 sec 37.8 MBytes 316 Mbits/sec
[ 5] 9.02-10.02 sec 37.5 MBytes 314 Mbits/sec
[ 5] 10.02-11.02 sec 38.1 MBytes 319 Mbits/sec
[ 5] 11.02-12.02 sec 37.8 MBytes 316 Mbits/sec
[ 5] 12.02-13.02 sec 37.8 MBytes 316 Mbits/sec
[ 5] 13.02-14.03 sec 36.9 MBytes 308 Mbits/sec
[ 5] 14.03-15.03 sec 35.1 MBytes 294 Mbits/sec
[ 5] 15.03-16.03 sec 37.2 MBytes 312 Mbits/sec
[ 5] 16.03-17.03 sec 38.0 MBytes 318 Mbits/sec
[ 5] 17.03-18.04 sec 30.5 MBytes 255 Mbits/sec
[ 5] 18.04-19.04 sec 35.0 MBytes 292 Mbits/sec
[ 5] 19.04-20.04 sec 20.9 MBytes 175 Mbits/sec
[ 5] 20.04-21.04 sec 38.9 MBytes 325 Mbits/sec
[ 5] 21.04-22.05 sec 39.1 MBytes 327 Mbits/sec
[ 5] 22.05-23.21 sec 36.6 MBytes 263 Mbits/sec
[ 5] 23.21-24.22 sec 38.5 MBytes 322 Mbits/sec
[ 5] 24.22-25.22 sec 38.2 MBytes 320 Mbits/sec
[ 5] 25.22-26.22 sec 31.1 MBytes 260 Mbits/sec
[ 5] 26.22-27.23 sec 38.2 MBytes 321 Mbits/sec
[ 5] 27.23-28.23 sec 38.9 MBytes 326 Mbits/sec
[ 5] 28.23-29.23 sec 38.5 MBytes 322 Mbits/sec
Sent
[ 5] 0.00-30.00 sec 1.05 GBytes 302 Mbits/sec
Received
[ 5] 0.00-30.00 sec 1.05 GBytes 302 Mbits/seciperf Done.
Done.4 Stream:
[ 5] local 192.168.1.2 port 3661 connected to 192.168.0.136 port 5201
[ 6] local 192.168.1.2 port 3662 connected to 192.168.0.136 port 5201
[ 7] local 192.168.1.2 port 3663 connected to 192.168.0.136 port 5201
[ 8] local 192.168.1.2 port 3664 connected to 192.168.0.136 port 5201
[ 5] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[ 6] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[ 7] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[ 8] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[SUM] 0.00-1.17 sec 8.50 MBytes 61.0 Mbits/sec
[ 5] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[ 6] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[ 7] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[ 8] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[SUM] 1.17-2.19 sec 8.50 MBytes 69.6 Mbits/sec
[ 5] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[ 6] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[ 7] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[ 8] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[SUM] 2.19-3.20 sec 8.50 MBytes 70.5 Mbits/sec
[ 5] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[ 6] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[ 7] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[ 8] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[SUM] 3.20-4.34 sec 8.50 MBytes 62.7 Mbits/sec
[ 5] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[ 6] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[ 7] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[ 8] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[SUM] 4.34-5.37 sec 8.50 MBytes 69.6 Mbits/sec
[ 5] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[ 6] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[ 7] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[ 8] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[SUM] 5.37-6.37 sec 8.50 MBytes 70.7 Mbits/sec
[ 5] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[ 6] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[ 7] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[ 8] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[SUM] 6.37-7.55 sec 8.50 MBytes 60.8 Mbits/sec
[ 5] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[ 6] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[ 7] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[ 8] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[SUM] 7.55-8.55 sec 8.50 MBytes 70.8 Mbits/sec
[ 5] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[ 6] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[ 7] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[ 8] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[SUM] 8.55-9.71 sec 8.50 MBytes 61.6 Mbits/sec
[ 5] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[ 6] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[ 7] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[ 8] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[SUM] 9.71-10.71 sec 8.50 MBytes 71.2 Mbits/sec
[ 5] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[ 6] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[ 7] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[ 8] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[SUM] 10.71-11.73 sec 8.50 MBytes 69.9 Mbits/sec
[ 5] 11.73-12.85 sec 3.75 MBytes 28.0 Mbits/sec
[ 6] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
[ 7] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
[ 8] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
[SUM] 11.73-12.85 sec 8.50 MBytes 63.5 Mbits/sec
[ 5] 12.85-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[ 6] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[ 7] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[ 8] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[SUM] 12.85-13.90 sec 8.50 MBytes 68.2 Mbits/sec
[ 5] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[ 6] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[ 7] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[ 8] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[SUM] 13.90-15.00 sec 8.50 MBytes 64.8 Mbits/sec
[ 5] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[ 6] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[ 7] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[ 8] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[SUM] 15.00-16.14 sec 8.50 MBytes 62.7 Mbits/sec
[ 5] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[ 6] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[ 7] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[ 8] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[SUM] 16.14-17.14 sec 8.50 MBytes 70.8 Mbits/sec
[ 5] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[ 6] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[ 7] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[ 8] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[SUM] 17.14-18.33 sec 8.50 MBytes 60.0 Mbits/sec
[ 5] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[ 6] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[ 7] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[ 8] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[SUM] 18.33-19.53 sec 8.50 MBytes 59.3 Mbits/sec
[ 5] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[ 6] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[ 7] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[ 8] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[SUM] 19.53-20.58 sec 8.50 MBytes 67.9 Mbits/sec
[ 5] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[ 6] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[ 7] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[ 8] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[SUM] 20.58-21.74 sec 8.50 MBytes 62.0 Mbits/sec
[ 5] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[ 6] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[ 7] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[ 8] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[SUM] 21.74-22.74 sec 8.50 MBytes 71.1 Mbits/sec
[ 5] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[ 6] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[ 7] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[ 8] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[SUM] 22.74-23.92 sec 8.50 MBytes 60.2 Mbits/sec
[ 5] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[ 6] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[ 7] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[ 8] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[SUM] 23.92-25.04 sec 8.50 MBytes 64.0 Mbits/sec
[ 5] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[ 6] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[ 7] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[ 8] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[SUM] 25.04-26.12 sec 8.50 MBytes 65.7 Mbits/sec
[ 5] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[ 6] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[ 7] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[ 8] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[SUM] 26.12-27.20 sec 8.50 MBytes 65.9 Mbits/sec
[ 5] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[ 6] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[ 7] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[ 8] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[SUM] 27.20-28.35 sec 8.50 MBytes 62.3 Mbits/sec
[ 5] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[ 6] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[ 7] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[ 8] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[SUM] 28.35-29.53 sec 8.50 MBytes 60.3 Mbits/sec
Sent
[ 5] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Sent
[ 6] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Sent
[ 7] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Sent
[ 8] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Total sent
[SUM] 0.00-30.20 sec 268 MBytes 74.3 Mbits/sec
Total received
[SUM] 0.00-30.20 sec 268 MBytes 74.3 Mbits/seciperf Done.
Done.- Netduma-FraserJun 29, 2019NetDuma PartnerThanks for doing that. Thats very strange, I will pass it onto the team to try and reproduce it.
Here is my XR450 test results: v40. Factory reset using default settings only.
XR450 and Duckware
BPS=948,560,264
0: 119,092,966 (952,743,728 bps)
1: 118,633,725 (949,069,800 bps)
2: 118,630,769 (949,046,152 bps)
3: 118,637,969 (949,103,752 bps)
4: 118,634,733 (949,077,864 bps)
5: 118,632,316 (949,058,528 bps)
6: 118,636,228 (949,089,824 bps)
7: 118,635,103 (949,080,824 bps)
8: 118,632,223 (949,057,784 bps)
9: 118,636,316 (949,090,528 bps)
10: 118,633,092 (949,064,736 bps)
11: 117,413,283 (939,306,264 bps)
12: 118,633,534 (949,068,272 bps)
13: 118,634,770 (949,078,160 bps)
14: 118,633,284 (949,066,272 bps)
15: 118,629,720 (949,037,760 bps)
16: 118,639,721 (949,117,768 bps)
17: 118,633,791 (949,070,328 bps)
18: 118,631,266 (949,050,128 bps)
19: 118,639,515 (949,116,120 bps)XR450 and iPerf
1 Stream
[ 5] 0.00-1.00 sec 44.2 MBytes 370 Mbits/sec
[ 5] 1.00-2.01 sec 46.2 MBytes 386 Mbits/sec
[ 5] 2.01-3.01 sec 50.1 MBytes 419 Mbits/sec
[ 5] 3.01-4.01 sec 17.0 MBytes 142 Mbits/sec
[ 5] 4.01-5.02 sec 39.8 MBytes 332 Mbits/sec
[ 5] 5.02-6.02 sec 61.5 MBytes 515 Mbits/sec
[ 5] 6.02-7.02 sec 49.0 MBytes 410 Mbits/sec
[ 5] 7.02-8.02 sec 48.5 MBytes 406 Mbits/sec
[ 5] 8.02-9.02 sec 60.2 MBytes 504 Mbits/sec
[ 5] 9.02-10.03 sec 61.6 MBytes 516 Mbits/sec
[ 5] 10.03-11.03 sec 49.0 MBytes 410 Mbits/sec
[ 5] 11.03-12.03 sec 62.0 MBytes 519 Mbits/sec
[ 5] 12.03-13.03 sec 48.0 MBytes 402 Mbits/sec
[ 5] 13.03-14.03 sec 45.2 MBytes 379 Mbits/sec
[ 5] 14.03-15.04 sec 58.2 MBytes 488 Mbits/sec
[ 5] 15.04-16.04 sec 50.0 MBytes 419 Mbits/sec
[ 5] 16.04-17.04 sec 56.8 MBytes 476 Mbits/sec
[ 5] 17.04-18.21 sec 57.5 MBytes 410 Mbits/sec
[ 5] 18.21-19.38 sec 57.2 MBytes 413 Mbits/sec
[ 5] 19.38-20.40 sec 45.1 MBytes 370 Mbits/sec
[ 5] 20.40-21.40 sec 48.6 MBytes 407 Mbits/sec
[ 5] 21.40-22.41 sec 45.8 MBytes 383 Mbits/sec
[ 5] 22.41-23.41 sec 60.4 MBytes 506 Mbits/sec
[ 5] 23.41-24.41 sec 45.2 MBytes 379 Mbits/sec
[ 5] 24.41-25.41 sec 52.1 MBytes 437 Mbits/sec
[ 5] 25.41-26.41 sec 63.0 MBytes 528 Mbits/sec
[ 5] 26.41-27.41 sec 62.6 MBytes 525 Mbits/sec
[ 5] 27.41-28.41 sec 58.4 MBytes 489 Mbits/sec
[ 5] 28.41-29.41 sec 58.2 MBytes 488 Mbits/sec
Sent
[ 5] 0.00-30.00 sec 1.50 GBytes 430 Mbits/sec
Received
[ 5] 0.00-30.00 sec 1.50 GBytes 430 Mbits/seciperf Done.
Done.4 Stream:
[ 5] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
[ 6] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
[ 7] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
[ 8] 0.00-1.00 sec 18.6 MBytes 156 Mbits/sec
[SUM] 0.00-1.00 sec 74.5 MBytes 623 Mbits/sec
[ 5] 1.00-2.01 sec 18.4 MBytes 153 Mbits/sec
[ 6] 1.00-2.01 sec 18.4 MBytes 153 Mbits/sec
[ 7] 1.00-2.01 sec 18.4 MBytes 153 Mbits/sec
[ 8] 1.00-2.01 sec 18.4 MBytes 153 Mbits/sec
[SUM] 1.00-2.01 sec 74.5 MBytes 622 Mbits/sec
[ 5] 2.01-3.01 sec 18.6 MBytes 155 Mbits/sec
[ 6] 2.01-3.01 sec 18.6 MBytes 155 Mbits/sec
[ 7] 2.01-3.01 sec 18.6 MBytes 155 Mbits/sec
[ 8] 2.01-3.01 sec 18.6 MBytes 155 Mbits/sec
[SUM] 2.01-3.01 sec 74.5 MBytes 621 Mbits/sec
[ 5] 3.01-4.02 sec 19.2 MBytes 161 Mbits/sec
[ 6] 3.01-4.02 sec 19.2 MBytes 161 Mbits/sec
[ 7] 3.01-4.02 sec 19.2 MBytes 161 Mbits/sec
[ 8] 3.01-4.02 sec 19.2 MBytes 161 Mbits/sec
[SUM] 3.01-4.02 sec 74.5 MBytes 624 Mbits/sec
[ 5] 4.02-5.05 sec 15.9 MBytes 129 Mbits/sec
[ 6] 4.02-5.05 sec 15.9 MBytes 129 Mbits/sec
[ 7] 4.02-5.05 sec 15.9 MBytes 129 Mbits/sec
[ 8] 4.02-5.05 sec 15.9 MBytes 129 Mbits/sec
[SUM] 4.02-5.05 sec 74.5 MBytes 604 Mbits/sec
[ 5] 5.05-6.05 sec 19.0 MBytes 159 Mbits/sec
[ 6] 5.05-6.05 sec 19.0 MBytes 159 Mbits/sec
[ 7] 5.05-6.05 sec 19.0 MBytes 159 Mbits/sec
[ 8] 5.05-6.05 sec 19.0 MBytes 159 Mbits/sec
[SUM] 5.05-6.05 sec 74.5 MBytes 623 Mbits/sec
[ 5] 6.05-7.06 sec 18.8 MBytes 157 Mbits/sec
[ 6] 6.05-7.06 sec 18.8 MBytes 157 Mbits/sec
[ 7] 6.05-7.06 sec 18.8 MBytes 157 Mbits/sec
[ 8] 6.05-7.06 sec 18.8 MBytes 157 Mbits/sec
[SUM] 6.05-7.06 sec 74.5 MBytes 622 Mbits/sec
[ 5] 7.06-8.06 sec 15.4 MBytes 129 Mbits/sec
[ 6] 7.06-8.06 sec 15.4 MBytes 129 Mbits/sec
[ 7] 7.06-8.06 sec 15.4 MBytes 129 Mbits/sec
[ 8] 7.06-8.06 sec 15.4 MBytes 129 Mbits/sec
[SUM] 7.06-8.06 sec 74.5 MBytes 624 Mbits/sec
[ 5] 8.06-9.06 sec 18.9 MBytes 158 Mbits/sec
[ 6] 8.06-9.06 sec 18.9 MBytes 158 Mbits/sec
[ 7] 8.06-9.06 sec 18.9 MBytes 158 Mbits/sec
[ 8] 8.06-9.06 sec 18.9 MBytes 158 Mbits/sec
[SUM] 8.06-9.06 sec 74.5 MBytes 623 Mbits/sec
[ 5] 9.06-10.07 sec 18.6 MBytes 156 Mbits/sec
[ 6] 9.06-10.07 sec 18.6 MBytes 156 Mbits/sec
[ 7] 9.06-10.07 sec 18.6 MBytes 156 Mbits/sec
[ 8] 9.06-10.07 sec 18.6 MBytes 156 Mbits/sec
[SUM] 9.06-10.07 sec 74.5 MBytes 623 Mbits/sec
[ 5] 10.07-11.07 sec 15.8 MBytes 132 Mbits/sec
[ 6] 10.07-11.07 sec 15.8 MBytes 132 Mbits/sec
[ 7] 10.07-11.07 sec 15.8 MBytes 132 Mbits/sec
[ 8] 10.07-11.07 sec 15.8 MBytes 132 Mbits/sec
[SUM] 10.07-11.07 sec 74.5 MBytes 624 Mbits/sec
[ 5] 11.07-12.07 sec 15.6 MBytes 131 Mbits/sec
[ 6] 11.07-12.07 sec 15.6 MBytes 131 Mbits/sec
[ 7] 11.07-12.07 sec 15.6 MBytes 131 Mbits/sec
[ 8] 11.07-12.07 sec 15.6 MBytes 131 Mbits/sec
[SUM] 11.07-12.07 sec 74.5 MBytes 624 Mbits/sec
[ 5] 12.07-13.08 sec 19.5 MBytes 162 Mbits/sec
[ 6] 12.07-13.08 sec 19.5 MBytes 162 Mbits/sec
[ 7] 12.07-13.08 sec 19.5 MBytes 162 Mbits/sec
[ 8] 12.07-13.08 sec 19.5 MBytes 162 Mbits/sec
[SUM] 12.07-13.08 sec 74.5 MBytes 621 Mbits/sec
[ 5] 13.08-14.08 sec 19.6 MBytes 164 Mbits/sec
[ 6] 13.08-14.08 sec 19.6 MBytes 164 Mbits/sec
[ 7] 13.08-14.08 sec 19.6 MBytes 164 Mbits/sec
[ 8] 13.08-14.08 sec 19.6 MBytes 164 Mbits/sec
[SUM] 13.08-14.08 sec 74.5 MBytes 623 Mbits/sec
[ 5] 14.08-15.08 sec 19.4 MBytes 162 Mbits/sec
[ 6] 14.08-15.08 sec 19.4 MBytes 162 Mbits/sec
[ 7] 14.08-15.08 sec 19.4 MBytes 162 Mbits/sec
[ 8] 14.08-15.08 sec 19.4 MBytes 162 Mbits/sec
[SUM] 14.08-15.08 sec 74.5 MBytes 624 Mbits/sec
[ 5] 15.08-16.08 sec 13.0 MBytes 109 Mbits/sec
[ 6] 15.08-16.08 sec 13.0 MBytes 109 Mbits/sec
[ 7] 15.08-16.08 sec 13.0 MBytes 109 Mbits/sec
[ 8] 15.08-16.08 sec 13.0 MBytes 109 Mbits/sec
[SUM] 15.08-16.08 sec 74.5 MBytes 622 Mbits/sec
[ 5] 16.08-17.09 sec 13.6 MBytes 114 Mbits/sec
[ 6] 16.08-17.09 sec 13.6 MBytes 114 Mbits/sec
[ 7] 16.08-17.09 sec 13.6 MBytes 114 Mbits/sec
[ 8] 16.08-17.09 sec 13.6 MBytes 114 Mbits/sec
[SUM] 16.08-17.09 sec 74.5 MBytes 624 Mbits/sec
[ 5] 17.09-18.09 sec 17.4 MBytes 145 Mbits/sec
[ 6] 17.09-18.09 sec 17.4 MBytes 145 Mbits/sec
[ 7] 17.09-18.09 sec 17.4 MBytes 145 Mbits/sec
[ 8] 17.09-18.09 sec 17.4 MBytes 145 Mbits/sec
[SUM] 17.09-18.09 sec 74.5 MBytes 624 Mbits/sec
[ 5] 18.09-19.09 sec 17.5 MBytes 146 Mbits/sec
[ 6] 18.09-19.09 sec 17.5 MBytes 146 Mbits/sec
[ 7] 18.09-19.09 sec 17.5 MBytes 146 Mbits/sec
[ 8] 18.09-19.09 sec 17.5 MBytes 146 Mbits/sec
[SUM] 18.09-19.09 sec 74.5 MBytes 623 Mbits/sec
[ 5] 19.09-20.09 sec 17.0 MBytes 142 Mbits/sec
[ 6] 19.09-20.09 sec 17.0 MBytes 142 Mbits/sec
[ 7] 19.09-20.09 sec 17.0 MBytes 142 Mbits/sec
[ 8] 19.09-20.09 sec 17.0 MBytes 142 Mbits/sec
[SUM] 19.09-20.09 sec 74.5 MBytes 624 Mbits/sec
[ 5] 20.09-21.25 sec 8.62 MBytes 62.3 Mbits/sec
[ 6] 20.09-21.25 sec 8.62 MBytes 62.3 Mbits/sec
[ 7] 20.09-21.25 sec 8.62 MBytes 62.3 Mbits/sec
[ 8] 20.09-21.25 sec 8.62 MBytes 62.3 Mbits/sec
[SUM] 20.09-21.25 sec 74.5 MBytes 538 Mbits/sec
[ 5] 21.25-22.26 sec 16.8 MBytes 140 Mbits/sec
[ 6] 21.25-22.26 sec 16.8 MBytes 140 Mbits/sec
[ 7] 21.25-22.26 sec 16.8 MBytes 140 Mbits/sec
[ 8] 21.25-22.26 sec 16.8 MBytes 140 Mbits/sec
[SUM] 21.25-22.26 sec 74.5 MBytes 623 Mbits/sec
[ 5] 22.26-23.26 sec 16.2 MBytes 136 Mbits/sec
[ 6] 22.26-23.26 sec 16.2 MBytes 136 Mbits/sec
[ 7] 22.26-23.26 sec 16.2 MBytes 136 Mbits/sec
[ 8] 22.26-23.26 sec 16.2 MBytes 136 Mbits/sec
[SUM] 22.26-23.26 sec 74.5 MBytes 624 Mbits/sec
[ 5] 23.26-24.26 sec 17.1 MBytes 143 Mbits/sec
[ 6] 23.26-24.26 sec 17.1 MBytes 143 Mbits/sec
[ 7] 23.26-24.26 sec 17.1 MBytes 143 Mbits/sec
[ 8] 23.26-24.26 sec 17.1 MBytes 143 Mbits/sec
[SUM] 23.26-24.26 sec 74.5 MBytes 623 Mbits/sec
[ 5] 24.26-25.27 sec 17.9 MBytes 149 Mbits/sec
[ 6] 24.26-25.27 sec 17.9 MBytes 149 Mbits/sec
[ 7] 24.26-25.27 sec 17.9 MBytes 149 Mbits/sec
[ 8] 24.26-25.27 sec 17.9 MBytes 149 Mbits/sec
[SUM] 24.26-25.27 sec 74.5 MBytes 621 Mbits/sec
[ 5] 25.27-26.27 sec 16.8 MBytes 140 Mbits/sec
[ 6] 25.27-26.27 sec 16.8 MBytes 140 Mbits/sec
[ 7] 25.27-26.27 sec 16.8 MBytes 140 Mbits/sec
[ 8] 25.27-26.27 sec 16.8 MBytes 140 Mbits/sec
[SUM] 25.27-26.27 sec 74.5 MBytes 622 Mbits/sec
[ 5] 26.27-27.28 sec 17.0 MBytes 142 Mbits/sec
[ 6] 26.27-27.28 sec 17.0 MBytes 142 Mbits/sec
[ 7] 26.27-27.28 sec 17.0 MBytes 142 Mbits/sec
[ 8] 26.27-27.28 sec 17.0 MBytes 142 Mbits/sec
[SUM] 26.27-27.28 sec 74.5 MBytes 622 Mbits/sec
[ 5] 27.28-28.38 sec 15.1 MBytes 115 Mbits/sec
[ 6] 27.28-28.38 sec 15.1 MBytes 115 Mbits/sec
[ 7] 27.28-28.38 sec 15.1 MBytes 115 Mbits/sec
[ 8] 27.28-28.38 sec 15.1 MBytes 115 Mbits/sec
[SUM] 27.28-28.38 sec 74.5 MBytes 568 Mbits/sec
[ 5] 28.38-29.38 sec 17.4 MBytes 145 Mbits/sec
[ 6] 28.38-29.38 sec 17.4 MBytes 145 Mbits/sec
[ 7] 28.38-29.38 sec 17.4 MBytes 145 Mbits/sec
[ 8] 28.38-29.38 sec 17.4 MBytes 145 Mbits/sec
[SUM] 28.38-29.38 sec 74.5 MBytes 623 Mbits/sec
Sent
[ 5] 0.00-30.00 sec 503 MBytes 141 Mbits/sec
Received
Sent
[ 6] 0.00-30.00 sec 503 MBytes 141 Mbits/sec
Received
Sent
[ 7] 0.00-30.00 sec 503 MBytes 141 Mbits/sec
Received
Sent
[ 8] 0.00-30.00 sec 503 MBytes 141 Mbits/sec
Received
Total sent
[SUM] 0.00-30.00 sec 1.96 GBytes 562 Mbits/sec
Total received
[SUM] 0.00-30.00 sec 1.96 GBytes 562 Mbits/seciperf Done.
Done.
