Jun 28, 2019Guru - Experienced User
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test. Seems like the HW NAT accelleration or Cut-Through that should be work...
Netduma-Fraser
Jun 29, 2019NetDuma Partner
That's odd, are your ethernet cables compatible with gigabit?
Put 1000/1000 in QoS and set to never and try again. Then also disable QoS completely in Anti-BB settings and try that.
Jun 29, 2019Guru - Experienced User
I run only CAT6 LAN cables. Same cables that tested the XR450 and other routers.
Those settings are default already after doing a factory reset. We expect routers to handle 900Mbps +- at factory defaults.
1 Stream:
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 34.6 MBytes 290 Mbits/sec
[ 5] 1.00-2.00 sec 36.8 MBytes 308 Mbits/sec
[ 5] 2.00-3.00 sec 37.0 MBytes 310 Mbits/sec
[ 5] 3.00-4.01 sec 37.5 MBytes 314 Mbits/sec
[ 5] 4.01-5.01 sec 37.5 MBytes 314 Mbits/sec
[ 5] 5.01-6.01 sec 37.4 MBytes 313 Mbits/sec
[ 5] 6.01-7.01 sec 29.8 MBytes 249 Mbits/sec
[ 5] 7.01-8.01 sec 37.5 MBytes 314 Mbits/sec
[ 5] 8.01-9.02 sec 37.8 MBytes 316 Mbits/sec
[ 5] 9.02-10.02 sec 37.5 MBytes 314 Mbits/sec
[ 5] 10.02-11.02 sec 38.1 MBytes 319 Mbits/sec
[ 5] 11.02-12.02 sec 37.8 MBytes 316 Mbits/sec
[ 5] 12.02-13.02 sec 37.8 MBytes 316 Mbits/sec
[ 5] 13.02-14.03 sec 36.9 MBytes 308 Mbits/sec
[ 5] 14.03-15.03 sec 35.1 MBytes 294 Mbits/sec
[ 5] 15.03-16.03 sec 37.2 MBytes 312 Mbits/sec
[ 5] 16.03-17.03 sec 38.0 MBytes 318 Mbits/sec
[ 5] 17.03-18.04 sec 30.5 MBytes 255 Mbits/sec
[ 5] 18.04-19.04 sec 35.0 MBytes 292 Mbits/sec
[ 5] 19.04-20.04 sec 20.9 MBytes 175 Mbits/sec
[ 5] 20.04-21.04 sec 38.9 MBytes 325 Mbits/sec
[ 5] 21.04-22.05 sec 39.1 MBytes 327 Mbits/sec
[ 5] 22.05-23.21 sec 36.6 MBytes 263 Mbits/sec
[ 5] 23.21-24.22 sec 38.5 MBytes 322 Mbits/sec
[ 5] 24.22-25.22 sec 38.2 MBytes 320 Mbits/sec
[ 5] 25.22-26.22 sec 31.1 MBytes 260 Mbits/sec
[ 5] 26.22-27.23 sec 38.2 MBytes 321 Mbits/sec
[ 5] 27.23-28.23 sec 38.9 MBytes 326 Mbits/sec
[ 5] 28.23-29.23 sec 38.5 MBytes 322 Mbits/sec
Sent
[ 5] 0.00-30.00 sec 1.05 GBytes 302 Mbits/sec
Received
iperf Done.
Done.
4 Stream:
[ 5] local 192.168.1.2 port 3661 connected to 192.168.0.136 port 5201
[ 6] local 192.168.1.2 port 3662 connected to 192.168.0.136 port 5201
[ 7] local 192.168.1.2 port 3663 connected to 192.168.0.136 port 5201
[ 8] local 192.168.1.2 port 3664 connected to 192.168.0.136 port 5201
[ 5] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[ 6] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[ 7] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[ 8] 0.00-1.17 sec 2.12 MBytes 15.3 Mbits/sec
[SUM] 0.00-1.17 sec 8.50 MBytes 61.0 Mbits/sec
[ 5] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[ 6] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[ 7] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[ 8] 1.17-2.19 sec 2.12 MBytes 17.4 Mbits/sec
[SUM] 1.17-2.19 sec 8.50 MBytes 69.6 Mbits/sec
[ 5] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[ 6] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[ 7] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[ 8] 2.19-3.20 sec 2.12 MBytes 17.6 Mbits/sec
[SUM] 2.19-3.20 sec 8.50 MBytes 70.5 Mbits/sec
[ 5] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[ 6] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[ 7] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[ 8] 3.20-4.34 sec 1.50 MBytes 11.1 Mbits/sec
[SUM] 3.20-4.34 sec 8.50 MBytes 62.7 Mbits/sec
[ 5] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[ 6] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[ 7] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[ 8] 4.34-5.37 sec 2.25 MBytes 18.4 Mbits/sec
[SUM] 4.34-5.37 sec 8.50 MBytes 69.6 Mbits/sec
[ 5] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[ 6] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[ 7] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[ 8] 5.37-6.37 sec 1.88 MBytes 15.6 Mbits/sec
[SUM] 5.37-6.37 sec 8.50 MBytes 70.7 Mbits/sec
[ 5] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[ 6] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[ 7] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[ 8] 6.37-7.55 sec 2.25 MBytes 16.1 Mbits/sec
[SUM] 6.37-7.55 sec 8.50 MBytes 60.8 Mbits/sec
[ 5] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[ 6] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[ 7] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[ 8] 7.55-8.55 sec 2.25 MBytes 18.7 Mbits/sec
[SUM] 7.55-8.55 sec 8.50 MBytes 70.8 Mbits/sec
[ 5] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[ 6] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[ 7] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[ 8] 8.55-9.71 sec 2.00 MBytes 14.5 Mbits/sec
[SUM] 8.55-9.71 sec 8.50 MBytes 61.6 Mbits/sec
[ 5] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[ 6] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[ 7] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[ 8] 9.71-10.71 sec 2.25 MBytes 18.8 Mbits/sec
[SUM] 9.71-10.71 sec 8.50 MBytes 71.2 Mbits/sec
[ 5] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[ 6] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[ 7] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[ 8] 10.71-11.73 sec 2.62 MBytes 21.6 Mbits/sec
[SUM] 10.71-11.73 sec 8.50 MBytes 69.9 Mbits/sec
[ 5] 11.73-12.85 sec 3.75 MBytes 28.0 Mbits/sec
[ 6] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
[ 7] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
[ 8] 11.73-12.86 sec 3.75 MBytes 28.0 Mbits/sec
[SUM] 11.73-12.85 sec 8.50 MBytes 63.5 Mbits/sec
[ 5] 12.85-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[ 6] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[ 7] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[ 8] 12.86-13.90 sec 2.75 MBytes 22.1 Mbits/sec
[SUM] 12.85-13.90 sec 8.50 MBytes 68.2 Mbits/sec
[ 5] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[ 6] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[ 7] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[ 8] 13.90-15.00 sec 3.25 MBytes 24.8 Mbits/sec
[SUM] 13.90-15.00 sec 8.50 MBytes 64.8 Mbits/sec
[ 5] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[ 6] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[ 7] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[ 8] 15.00-16.14 sec 1.75 MBytes 12.9 Mbits/sec
[SUM] 15.00-16.14 sec 8.50 MBytes 62.7 Mbits/sec
[ 5] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[ 6] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[ 7] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[ 8] 16.14-17.14 sec 2.12 MBytes 17.7 Mbits/sec
[SUM] 16.14-17.14 sec 8.50 MBytes 70.8 Mbits/sec
[ 5] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[ 6] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[ 7] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[ 8] 17.14-18.33 sec 2.38 MBytes 16.8 Mbits/sec
[SUM] 17.14-18.33 sec 8.50 MBytes 60.0 Mbits/sec
[ 5] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[ 6] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[ 7] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[ 8] 18.33-19.53 sec 2.38 MBytes 16.6 Mbits/sec
[SUM] 18.33-19.53 sec 8.50 MBytes 59.3 Mbits/sec
[ 5] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[ 6] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[ 7] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[ 8] 19.53-20.58 sec 3.00 MBytes 23.9 Mbits/sec
[SUM] 19.53-20.58 sec 8.50 MBytes 67.9 Mbits/sec
[ 5] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[ 6] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[ 7] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[ 8] 20.58-21.74 sec 2.12 MBytes 15.5 Mbits/sec
[SUM] 20.58-21.74 sec 8.50 MBytes 62.0 Mbits/sec
[ 5] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[ 6] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[ 7] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[ 8] 21.74-22.74 sec 2.38 MBytes 19.9 Mbits/sec
[SUM] 21.74-22.74 sec 8.50 MBytes 71.1 Mbits/sec
[ 5] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[ 6] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[ 7] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[ 8] 22.74-23.92 sec 4.38 MBytes 31.0 Mbits/sec
[SUM] 22.74-23.92 sec 8.50 MBytes 60.2 Mbits/sec
[ 5] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[ 6] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[ 7] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[ 8] 23.92-25.04 sec 3.38 MBytes 25.4 Mbits/sec
[SUM] 23.92-25.04 sec 8.50 MBytes 64.0 Mbits/sec
[ 5] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[ 6] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[ 7] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[ 8] 25.04-26.12 sec 3.25 MBytes 25.1 Mbits/sec
[SUM] 25.04-26.12 sec 8.50 MBytes 65.7 Mbits/sec
[ 5] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[ 6] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[ 7] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[ 8] 26.12-27.20 sec 1.62 MBytes 12.6 Mbits/sec
[SUM] 26.12-27.20 sec 8.50 MBytes 65.9 Mbits/sec
[ 5] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[ 6] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[ 7] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[ 8] 27.20-28.35 sec 1.75 MBytes 12.8 Mbits/sec
[SUM] 27.20-28.35 sec 8.50 MBytes 62.3 Mbits/sec
[ 5] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[ 6] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[ 7] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[ 8] 28.35-29.53 sec 2.00 MBytes 14.2 Mbits/sec
[SUM] 28.35-29.53 sec 8.50 MBytes 60.3 Mbits/sec
Sent
[ 5] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Sent
[ 6] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Sent
[ 7] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Sent
[ 8] 0.00-30.20 sec 66.9 MBytes 18.6 Mbits/sec
Received
Total sent
[SUM] 0.00-30.20 sec 268 MBytes 74.3 Mbits/sec
Total received
iperf Done.
Done.
