Jun 28, 2019Guru - Experienced User
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test. Seems like the HW NAT accelleration or Cut-Through that should be work...
Jun 29, 2019Guru - Experienced User
XR450 and iPerf
5 Stream:
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[ 6] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[ 7] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[ 8] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[ 9] 0.00-1.01 sec 12.1 MBytes 101 Mbits/sec
[SUM] 0.00-1.01 sec 60.6 MBytes 505 Mbits/sec
[ 5] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[ 6] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[ 7] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[ 8] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[ 9] 1.01-2.01 sec 14.5 MBytes 121 Mbits/sec
[SUM] 1.01-2.01 sec 60.6 MBytes 505 Mbits/sec
[ 5] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[ 6] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[ 7] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[ 8] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[ 9] 2.01-3.02 sec 15.2 MBytes 128 Mbits/sec
[SUM] 2.01-3.02 sec 60.6 MBytes 507 Mbits/sec
[ 5] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[ 6] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[ 7] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[ 8] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[ 9] 3.02-4.02 sec 15.1 MBytes 127 Mbits/sec
[SUM] 3.02-4.02 sec 60.6 MBytes 507 Mbits/sec
[ 5] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[ 6] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[ 7] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[ 8] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[ 9] 4.02-5.02 sec 14.9 MBytes 124 Mbits/sec
[SUM] 4.02-5.02 sec 60.6 MBytes 507 Mbits/sec
[ 5] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[ 6] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[ 7] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[ 8] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[ 9] 5.02-6.03 sec 15.6 MBytes 130 Mbits/sec
[SUM] 5.02-6.03 sec 60.6 MBytes 505 Mbits/sec
[ 5] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[ 6] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[ 7] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[ 8] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[ 9] 6.03-7.03 sec 15.6 MBytes 131 Mbits/sec
[SUM] 6.03-7.03 sec 60.6 MBytes 507 Mbits/sec
[ 5] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[ 6] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[ 7] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[ 8] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[ 9] 7.03-8.04 sec 13.8 MBytes 115 Mbits/sec
[SUM] 7.03-8.04 sec 60.6 MBytes 506 Mbits/sec
[ 5] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[ 6] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[ 7] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[ 8] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[ 9] 8.04-9.04 sec 15.8 MBytes 132 Mbits/sec
[SUM] 8.04-9.04 sec 60.6 MBytes 507 Mbits/sec
[ 5] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[ 6] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[ 7] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[ 8] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[ 9] 9.04-10.04 sec 16.0 MBytes 134 Mbits/sec
[SUM] 9.04-10.04 sec 60.6 MBytes 508 Mbits/sec
[ 5] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[ 6] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[ 7] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[ 8] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[ 9] 10.04-11.05 sec 15.0 MBytes 125 Mbits/sec
[SUM] 10.04-11.05 sec 60.6 MBytes 506 Mbits/sec
[ 5] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[ 6] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[ 7] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[ 8] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[ 9] 11.05-12.20 sec 14.1 MBytes 103 Mbits/sec
[SUM] 11.05-12.20 sec 60.6 MBytes 442 Mbits/sec
[ 5] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[ 6] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[ 7] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[ 8] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[ 9] 12.20-13.20 sec 12.4 MBytes 104 Mbits/sec
[SUM] 12.20-13.20 sec 60.6 MBytes 508 Mbits/sec
[ 5] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[ 6] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[ 7] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[ 8] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[ 9] 13.20-14.20 sec 16.5 MBytes 138 Mbits/sec
[SUM] 13.20-14.20 sec 60.6 MBytes 508 Mbits/sec
[ 5] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[ 6] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[ 7] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[ 8] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[ 9] 14.20-15.21 sec 16.5 MBytes 137 Mbits/sec
[SUM] 14.20-15.21 sec 60.6 MBytes 505 Mbits/sec
[ 5] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[ 6] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[ 7] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[ 8] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[ 9] 15.21-16.21 sec 16.4 MBytes 137 Mbits/sec
[SUM] 15.21-16.21 sec 60.6 MBytes 508 Mbits/sec
[ 5] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[ 6] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[ 7] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[ 8] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[ 9] 16.21-17.22 sec 16.5 MBytes 138 Mbits/sec
[SUM] 16.21-17.22 sec 60.6 MBytes 506 Mbits/sec
[ 5] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[ 6] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[ 7] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[ 8] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[ 9] 17.22-18.22 sec 16.0 MBytes 134 Mbits/sec
[SUM] 17.22-18.22 sec 60.6 MBytes 506 Mbits/sec
[ 5] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[ 6] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[ 7] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[ 8] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[ 9] 18.22-19.22 sec 12.6 MBytes 106 Mbits/sec
[SUM] 18.22-19.22 sec 60.6 MBytes 508 Mbits/sec
[ 5] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[ 6] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[ 7] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[ 8] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[ 9] 19.22-20.23 sec 16.0 MBytes 133 Mbits/sec
[SUM] 19.22-20.23 sec 60.6 MBytes 506 Mbits/sec
[ 5] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[ 6] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[ 7] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[ 8] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[ 9] 20.23-21.23 sec 16.0 MBytes 134 Mbits/sec
[SUM] 20.23-21.23 sec 60.6 MBytes 506 Mbits/sec
[ 5] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[ 6] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[ 7] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[ 8] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[ 9] 21.23-22.24 sec 16.0 MBytes 133 Mbits/sec
[SUM] 21.23-22.24 sec 60.6 MBytes 505 Mbits/sec
[ 5] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[ 6] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[ 7] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[ 8] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[ 9] 22.24-23.25 sec 16.2 MBytes 136 Mbits/sec
[SUM] 22.24-23.25 sec 60.6 MBytes 506 Mbits/sec
[ 5] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[ 6] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[ 7] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[ 8] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[ 9] 23.25-24.25 sec 16.4 MBytes 137 Mbits/sec
[SUM] 23.25-24.25 sec 60.6 MBytes 508 Mbits/sec
[ 5] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[ 6] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[ 7] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[ 8] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[ 9] 24.25-25.25 sec 12.8 MBytes 107 Mbits/sec
[SUM] 24.25-25.25 sec 60.6 MBytes 507 Mbits/sec
[ 5] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[ 6] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[ 7] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[ 8] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[ 9] 25.25-26.25 sec 16.4 MBytes 137 Mbits/sec
[SUM] 25.25-26.25 sec 60.6 MBytes 507 Mbits/sec
[ 5] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[ 6] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[ 7] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[ 8] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[ 9] 26.25-27.26 sec 14.8 MBytes 123 Mbits/sec
[SUM] 26.25-27.26 sec 60.6 MBytes 507 Mbits/sec
[ 5] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[ 6] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[ 7] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[ 8] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[ 9] 27.26-28.26 sec 8.00 MBytes 66.8 Mbits/sec
[SUM] 27.26-28.26 sec 60.6 MBytes 507 Mbits/sec
[ 5] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[ 6] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[ 7] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[ 8] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[ 9] 28.26-29.27 sec 12.6 MBytes 105 Mbits/sec
[SUM] 28.26-29.27 sec 60.6 MBytes 506 Mbits/sec
Sent
[ 5] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Sent
[ 6] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Sent
[ 7] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Sent
[ 8] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Sent
[ 9] 0.00-30.00 sec 442 MBytes 124 Mbits/sec
Received
Total sent
[SUM] 0.00-30.00 sec 2.16 GBytes 618 Mbits/sec
Total received
iperf Done.
Netduma-Fraser
Jun 30, 2019NetDuma Partner
Thanks for that, I believe iPerf will be slower as we use very specific commands for that to ensure it operates optimally. The team are aware now so hopefully they can reproduce the issue.
