Jun 28, 2019Guru - Experienced User
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test. Seems like the HW NAT accelleration or Cut-Through that should be work...
Jun 30, 2019Guru - Experienced User
Hoping to see improvements on the XR700. :smileywink:
