Jun 28, 2019Guru - Experienced User
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test. Seems like the HW NAT accelleration or Cut-Through that should be work...
Jul 04, 2019Guru - Experienced User
I need to make a small correction with my initial test results.
Those initial iPerf test results posted were testing the uplink speed of the WAN port. I wasn't paying attention when the test was running however looking at a network speed meter I have on my test PCs they show which direction the data flow is going, Up or DL. I didn't relize that the configuration of the PC thru the router and switch and how iPerf works and I had it configured, it seems having the iPerf Server configured on the PC thats connected to the switch and the iPerf client PC connected to the router under test, the direction of data flow is for the UP link speed. Changing the iPerf settings on the PC thats connected to the LAN switch to Client and the PC thats connected to the router under test to Server, this sends the data flow as DOWNLOAD link speed.
So after checking things again, I reset the XR router again and ensured the PCs and iPerf was confgured for the DOWNLOAD speed test. Still not seeing anything close to 900mpbs unfortunately.
Download Router mode
1 Stream
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.03 sec 25.1 MBytes 204 Mbits/sec
[ 5] 1.03-2.03 sec 30.1 MBytes 252 Mbits/sec
[ 5] 2.03-3.03 sec 38.8 MBytes 325 Mbits/sec
[ 5] 3.03-4.03 sec 38.9 MBytes 326 Mbits/sec
[ 5] 4.03-5.04 sec 37.9 MBytes 316 Mbits/sec
[ 5] 5.04-6.04 sec 22.9 MBytes 191 Mbits/sec
[ 5] 6.04-7.04 sec 31.2 MBytes 262 Mbits/sec
[ 5] 7.04-8.04 sec 38.8 MBytes 324 Mbits/sec
[ 5] 8.04-9.05 sec 31.6 MBytes 265 Mbits/sec
[ 5] 9.05-10.05 sec 38.5 MBytes 323 Mbits/sec
[ 5] 10.05-11.05 sec 38.2 MBytes 320 Mbits/sec
[ 5] 11.05-12.05 sec 23.4 MBytes 196 Mbits/sec
[ 5] 12.05-13.05 sec 31.4 MBytes 262 Mbits/sec
[ 5] 13.05-14.06 sec 39.2 MBytes 328 Mbits/sec
[ 5] 14.06-15.06 sec 38.5 MBytes 322 Mbits/sec
[ 5] 15.06-16.06 sec 31.2 MBytes 261 Mbits/sec
[ 5] 16.06-17.07 sec 38.9 MBytes 325 Mbits/sec
[ 5] 17.07-18.07 sec 38.9 MBytes 326 Mbits/sec
[ 5] 18.07-19.07 sec 31.2 MBytes 262 Mbits/sec
[ 5] 19.07-20.07 sec 30.1 MBytes 252 Mbits/sec
[ 5] 20.07-21.07 sec 30.1 MBytes 252 Mbits/sec
[ 5] 21.07-22.08 sec 21.8 MBytes 182 Mbits/sec
[ 5] 22.08-23.08 sec 29.1 MBytes 244 Mbits/sec
[ 5] 23.08-24.08 sec 31.2 MBytes 261 Mbits/sec
[ 5] 24.08-25.08 sec 38.6 MBytes 323 Mbits/sec
[ 5] 25.08-26.08 sec 38.8 MBytes 324 Mbits/sec
[ 5] 26.08-27.09 sec 31.2 MBytes 262 Mbits/sec
[ 5] 27.09-28.09 sec 31.0 MBytes 260 Mbits/sec
[ 5] 28.09-29.09 sec 37.4 MBytes 313 Mbits/sec
[ 5] 29.09-30.09 sec 30.0 MBytes 251 Mbits/sec
Sent
[ 5] 0.00-30.33 sec 996 MBytes 275 Mbits/sec
Received
4 Stream
[ 5] 0.00-1.02 sec 5.12 MBytes 42.3 Mbits/sec
[ 6] 0.00-1.02 sec 5.12 MBytes 42.3 Mbits/sec
[ 7] 0.00-1.02 sec 5.00 MBytes 41.3 Mbits/sec
[ 8] 0.00-1.02 sec 5.00 MBytes 41.3 Mbits/sec
[SUM] 0.00-1.02 sec 20.2 MBytes 167 Mbits/sec
[ 5] 1.02-2.02 sec 5.50 MBytes 46.0 Mbits/sec
[ 6] 1.02-2.02 sec 5.38 MBytes 45.0 Mbits/sec
[ 7] 1.02-2.02 sec 5.50 MBytes 46.0 Mbits/sec
[ 8] 1.02-2.02 sec 5.50 MBytes 46.0 Mbits/sec
[SUM] 1.02-2.02 sec 20.2 MBytes 169 Mbits/sec
[ 5] 2.02-3.02 sec 6.00 MBytes 50.2 Mbits/sec
[ 6] 2.02-3.02 sec 6.12 MBytes 51.3 Mbits/sec
[ 7] 2.02-3.02 sec 6.00 MBytes 50.2 Mbits/sec
[ 8] 2.02-3.02 sec 6.00 MBytes 50.2 Mbits/sec
[SUM] 2.02-3.02 sec 20.2 MBytes 170 Mbits/sec
[ 5] 3.02-4.03 sec 1.75 MBytes 14.6 Mbits/sec
[ 6] 3.02-4.03 sec 1.62 MBytes 13.6 Mbits/sec
[ 7] 3.02-4.03 sec 1.75 MBytes 14.6 Mbits/sec
[ 8] 3.02-4.03 sec 1.75 MBytes 14.6 Mbits/sec
[SUM] 3.02-4.03 sec 20.2 MBytes 169 Mbits/sec
[ 5] 4.03-5.03 sec 1.88 MBytes 15.7 Mbits/sec
[ 6] 4.03-5.03 sec 2.00 MBytes 16.7 Mbits/sec
[ 7] 4.03-5.03 sec 2.00 MBytes 16.7 Mbits/sec
[ 8] 4.03-5.03 sec 2.00 MBytes 16.7 Mbits/sec
[SUM] 4.03-5.03 sec 20.2 MBytes 170 Mbits/sec
[ 5] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
[ 6] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
[ 7] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
[ 8] 5.03-6.03 sec 4.00 MBytes 33.4 Mbits/sec
[SUM] 5.03-6.03 sec 20.2 MBytes 169 Mbits/sec
[ 5] 6.03-7.03 sec 4.00 MBytes 33.5 Mbits/sec
[ 6] 6.03-7.03 sec 3.88 MBytes 32.5 Mbits/sec
[ 7] 6.03-7.03 sec 3.88 MBytes 32.5 Mbits/sec
[ 8] 6.03-7.03 sec 3.88 MBytes 32.5 Mbits/sec
[SUM] 6.03-7.03 sec 20.2 MBytes 170 Mbits/sec
Sent
[ 5] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
Received
Sent
[ 6] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
Received
Sent
[ 7] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
Received
Sent
[ 8] 0.00-30.34 sec 98.1 MBytes 27.1 Mbits/sec
Received
Total sent
[SUM] 0.00-30.34 sec 392 MBytes 109 Mbits/sec
Total received
Duckware still reports same:
BPS=370,396,672
0: 43,215,838 (345,726,704 bps)
1: 44,711,842 (357,694,736 bps)
2: 45,684,960 (365,479,680 bps)
3: 46,070,614 (368,564,912 bps)
4: 46,952,917 (375,623,336 bps)
5: 46,035,429 (368,283,432 bps)
6: 46,825,266 (374,602,128 bps)
7: 46,501,707 (372,013,656 bps)
8: 46,668,326 (373,346,608 bps)
9: 46,320,527 (370,564,216 bps)
10: 46,748,672 (373,989,376 bps)
11: 46,432,389 (371,459,112 bps)
12: 45,312,645 (362,501,160 bps)
13: 46,491,542 (371,932,336 bps)
14: 46,208,458 (369,667,664 bps)
15: 46,506,975 (372,055,800 bps)
16: 46,208,476 (369,667,808 bps)
17: 46,794,457 (374,355,656 bps)
18: 46,392,063 (371,136,504 bps)
19: 46,824,360 (374,594,880 bps)
