Jun 28, 2019Guru - Experienced User
XR700 is not supporting 900Mb+- on the WAN to LAN test
So using the following simple test method and test program, I'm not seeing anything near 900mbps on the WAN to LAN test. Seems like the HW NAT accelleration or Cut-Through that should be work...
-Donovan-
Jul 05, 2019Luminary
FURRYe38 wrote:It's interesting that Duckwares test saw 900mbps while in AP mode:
BPS=945,153,424
0: 118,618,928 (948,951,424 bps)
1: 118,005,184 (944,041,472 bps)
2: 118,211,457 (945,691,656 bps)
3: 118,307,869 (946,462,952 bps)
4: 118,317,792 (946,542,336 bps)
5: 118,320,105 (946,560,840 bps)
6: 117,452,558 (939,620,464 bps)
7: 118,312,032 (946,496,256 bps)
8: 118,319,123 (946,552,984 bps)
9: 118,246,052 (945,968,416 bps)
10: 117,973,528 (943,788,224 bps)
11: 117,933,981 (943,471,848 bps)
12: 118,321,485 (946,571,880 bps)
13: 117,904,900 (943,239,200 bps)
14: 118,323,900 (946,591,200 bps)
15: 118,319,751 (946,558,008 bps)
16: 117,919,242 (943,353,936 bps)
17: 118,305,083 (946,440,664 bps)
18: 118,313,001 (946,504,008 bps)
19: 117,931,813 (943,454,504 bps)
I saw another interesting thing too in the setup wizard at the Checking internet speed on the WAN Port, the speedtest can read the correct speed at 940Mbps/50Mbps and sometime is totally way off. Once the setup is done and you redo a speed test, you can't get the gigabit speed on ISP speed test or speedtest.net.
Netduma-Fraser
Jul 05, 2019NetDuma Partner
Thank you for the updated information, I have asked for news on the matter from the team.
