n00b3
Aug 16, 2020Aspirant
XR700 Issues
So I got an XR700. Great router features wise but am having a bunch of issues. I will list below. I am trying to connect a bunch of devices via LAN. When I connect they mostly work fine however w...
Netduma-Fraser
Aug 18, 2020NetDuma Partner
Give your devices a reserved IP address in LAN Settings. The one device that has trouble have you given it static network settings on the device itself? Look on the Device Manager at the table view, do all ports show 1000Mbits link speed? Have you entered your speeds in the Anti-Bufferbloat menu?
- n00b3Aug 19, 2020Aspirant
I was hoping not to have to go down the path of reserved IP's as I have a lot of devices and connecting them 1 by 1 and assigning IP's will be slow. The one that keeps connecting to an incorrect IP isn't set to static IP as if I plug my old router in it works fine and connects to an IP under 192.168.1.x. All devices are showing 1000Mbits on Network Map. Where is the Anti Bufferbloat menu?
- michaelkenwardAug 19, 2020Guru - Experienced User
n00b3 wrote:
I was hoping not to have to go down the path of reserved IP's ..
Trying setting the troublesome device to have a fixed IP address?
- Netduma-FraserAug 19, 2020NetDuma Partner
As above, just give a few reserved IPs to the devices that have the most trouble/are most important and see if that helps first. Anti-Bufferbloat menu is on the top left of the panel on the QoS page.
