n00b3
Aug 16, 2020Aspirant
XR700 Issues
So I got an XR700. Great router features wise but am having a bunch of issues. I will list below. I am trying to connect a bunch of devices via LAN. When I connect they mostly work fine however w...
n00b3
Aug 19, 2020Aspirant
I was hoping not to have to go down the path of reserved IP's as I have a lot of devices and connecting them 1 by 1 and assigning IP's will be slow. The one that keeps connecting to an incorrect IP isn't set to static IP as if I plug my old router in it works fine and connects to an IP under 192.168.1.x. All devices are showing 1000Mbits on Network Map. Where is the Anti Bufferbloat menu?
michaelkenward
Aug 19, 2020Guru - Experienced User
n00b3 wrote:
I was hoping not to have to go down the path of reserved IP's ..
Trying setting the troublesome device to have a fixed IP address?
- Netduma-FraserAug 19, 2020NetDuma Partner
As above, just give a few reserved IPs to the devices that have the most trouble/are most important and see if that helps first. Anti-Bufferbloat menu is on the top left of the panel on the QoS page.
- michaelkenwardAug 19, 2020Guru - Experienced User
Is that reserved on the router or assigned on the device?
Both have their uses.
It might help to say which devices cause problems.
- Netduma-FraserAug 19, 2020NetDuma PartnerReserved on the router I would suggest first.
