buck84
Dec 06, 2021Tutor
XR700 keep getting connection issues DHCP?
I keep getting "connected no ip address" or "Unable to connect to the internet" We have maybe 30 devices connected and it is happening intermittently The firmware is V1.0.1.46 I have a...
Dec 06, 2021Guru - Experienced User
Looks like you have a router in front of the XR router already.
Have you setup some IP address reservations for your devices ON the router?
X700 is not a valid model for a extender. EX#### or EAX##
- buck84Dec 06, 2021Tutor
The modem is an Arris NVG589 from 2015
The WAP is Cisco VEN501-AT
Both WAP and the netgear XR700 are attached to the Arris with CAT5e cable
The Netgear has been attached for about a year and these issues started maybe 60 days ago.
Thanks for the quick reply
- Netduma-LiamDec 06, 2021NetDuma Partner
Are any devices connected directly to the XR700? Are they also experiencing this issue or is it only devices connected to the AP?
Are you able to see all the devices connected to the AP in device manager, or is it just the AP that you can see?
Do these devices show as going between online and offline in Device Manager, or do they show as being consistently offline?
If you reserve IP addresses for each individual device that's having this issue, does the problem stop?
- I have a PC and printer connected by Cat5e to the XR700 and have not had issues
- I can see all the devices connected -- some to 2.4 some to 5 but also a binch "not connected"
- When I delete the non-connected devices some so "can't delete, device online"
- Some of both
- I can see some switch from online to offline and some just stay offline
- I gave one PC a static address ...87 in MAC network settings
- It worked for a while, but has now stopped
- I do not know how to reserve in the XR700 (I would also like to prioritze the kids computers when taking an exam in QOS but could not figure that out either.)
Thanks
- FURRYe38Dec 06, 2021Guru - Experienced User
What mode is the modem working in? Router or AP mode. Your modem already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setupI would try option #1 or #2...
