IJayJayI
Jan 31, 2019Apprentice
XR700 Keeps Kicking Offline
I have the XR700 Router with the CM1000 Cable Modem. Every time i try and play on Xbox live even just sitting in a party chat i keep getting kicked offline every few minutes. I have tried to factory...
Rick6922
Jan 31, 2019Luminary
I have the same modem and had the same problem. I went to WAN setup and added xboxs ip , then checked only the 2nd and 4th box. then went to advanced settings to UPnP and disabled it. added the xboxs static ip in LAN setup and it hasnt happened again on the new FW. oh yeah, I also port fowarded the ports used for cod bo4 on router[3074-3075]
IJayJayI
yeah i have all ports forwarded as well. And i think i figured out the issue for me. Had to disable IPv6. For some reason the router cannot handle IPv6 for consoles it seems.
