IJayJayI
Jan 31, 2019Apprentice
XR700 Keeps Kicking Offline
I have the XR700 Router with the CM1000 Cable Modem. Every time i try and play on Xbox live even just sitting in a party chat i keep getting kicked offline every few minutes. I have tried to factory...
IJayJayI
Feb 01, 2019Apprentice
Yeah, I always reboot everything in this process. I have downgraded to all the FWs there are only 3 firmwares for this device and went through all three. I haven't been kicked all last night and and believe the problem to be the IPv6. I had IPv6 enabled and once disabled it has not kicked me. There seems to be some type of conflict with IPv6 and consoles with this particular router, I'm not sure why but that was the issue for me.
Feb 01, 2019Guru - Experienced User
Do you have native IPv6 from your ISP, if you don't i can be disabled.
If you do, and you thing that is a problem in the FW, I would file a support ticket here:
- Rick6922Feb 01, 2019Luminary
you really need ivp6 if you can, try what I did first [ a couple replys back] and see if that works so you can have ping ass.
- IJayJayIFeb 01, 2019ApprenticeYeah, I will try yours because I want to keep IPv6 it's much better and I've notice an increase in ping without IPv6.
- IJayJayIFeb 01, 2019ApprenticeYes I have Native IPv6 with Xfinity.
