IJayJayI
Jan 31, 2019Apprentice
XR700 Keeps Kicking Offline
I have the XR700 Router with the CM1000 Cable Modem. Every time i try and play on Xbox live even just sitting in a party chat i keep getting kicked offline every few minutes. I have tried to factory...
Rick6922
Jan 31, 2019Luminary
I have the same modem and had the same problem. I went to WAN setup and added xboxs ip , then checked only the 2nd and 4th box. then went to advanced settings to UPnP and disabled it. added the xboxs static ip in LAN setup and it hasnt happened again on the new FW. oh yeah, I also port fowarded the ports used for cod bo4 on router[3074-3075]
IJayJayI
Feb 01, 2019Apprentice
I have tried to forward all ports, and enabling IPv6 while disabling UPnP and still getting kicked. Still trying several things -- since I know IPv6 is very important and want to use it. --going to make a ticket with NG if we cannot figure it out. I want everyone to be able to know how to fix this issue.
- IJayJayIFeb 01, 2019ApprenticeSo far I set IPv6 as Enabled with internet Passthrough. It's working at the moment but will update yall as I figure this out, unless anyone else has a solution.
- Shikwan68Feb 02, 2019Star
Just to inform everyone; I've read somewhere that the XR500 & XR700 are kicking Xbox users offline. Netgear & MS are working on a fix but the current solution is to TURN OFF 'Instant On' in the Xbox Settings.
- IJayJayIFeb 02, 2019Apprentice
Thanks for the reply, My Xbox is and has always had Instan On turned off. The router has and issue with MS IPv6, somehow it is incompatible in some form or another. The IPv6 keeps getting disconnected, and i do not know if it is Netgear's end, Microsoft's end, or both.
