IJayJayI
Jan 31, 2019Apprentice
XR700 Keeps Kicking Offline
I have the XR700 Router with the CM1000 Cable Modem. Every time i try and play on Xbox live even just sitting in a party chat i keep getting kicked offline every few minutes. I have tried to factory...
Feb 07, 2019Guru - Experienced User
FYI, IPv6 is not required for xbox or game play on xbox one. It's is a nice feature to have if your ISP natively supports it and the router is configured correctly to take advanage of it. You don't have to have it for xbox gaming. My ISP doesn't support it as of yet so I always keep it disabled. One day I we might see it. :smileyfrustrated:
IJayJayI
Feb 07, 2019Apprentice
Yes that is true, IPv6 is not a requirement but it's suppose to run better since it is highly recommend even by Microsoft. I feel like I lag more on IPv4 than IPv6 (except now, with this whole issue) trying to do much more testing to make it to where I can play smoothly with IPv6. It's native to my ISP so I'd like to utilize it.
- IJayJayIFeb 07, 2019ApprenticeI'd like to thank everyone for everyone's support in keeping this thread open and active until we get to the bottom of this. I've seen this is also an issue with PS4 not just Xbox. We will get a solution!
- FURRYe38Feb 07, 2019Guru - Experienced User
I would do this, connect the xbox one directly to the ISP modem with out the router being online. The CM modem should auto pass thru any IPv6 to the xbox. You'll need to ensure the xbox is connected and configured correctly. It should seen IPv6.
Play some games. Do you see same problems with this configuration as well? If not, then there maybe an issue between the CM modem and the router/FW when using IPv6.
IJayJayI wrote:
Yes that is true, IPv6 is not a requirement but it's suppose to run better since it is highly recommend even by Microsoft. I feel like I lag more on IPv4 than IPv6 (except now, with this whole issue) trying to do much more testing to make it to where I can play smoothly with IPv6. It's native to my ISP so I'd like to utilize it.- IJayJayIFeb 07, 2019ApprenticeI'll certainly try that out. Thanks
- Netduma-FraserFeb 07, 2019NetDuma PartnerI would not say that QoS is unneeded for you. Those other devices when you're gaming could suddenly start downloading and that would affect you. I would highly recommend using it.
