IJayJayI
Jan 31, 2019Apprentice
XR700 Keeps Kicking Offline
I have the XR700 Router with the CM1000 Cable Modem. Every time i try and play on Xbox live even just sitting in a party chat i keep getting kicked offline every few minutes. I have tried to factory...
IJayJayI
Mar 26, 2019Apprentice
Update:
So far the newest firmware+GTek10G worked well at first.
It works well with the IPv6 now with Xbox. Now having another major issue with the new firmware.
I have to constantly restart the router daily. It keeps loosing internet connection until I restart it. It's quite frustrating. (Can Netgear please fix these issues?, Again a $500 router that doesn't work better than a $80 router)
Mar 26, 2019Guru - Experienced User
I would submit a support ticket to let NG know what your seeing with the new FW.
- Netduma-FraserMar 26, 2019NetDuma PartnerI would actually recommend going back to the .8 firmware and see if this issue exists there.
- IJayJayIMar 26, 2019ApprenticeThanks I'll give it a try, from the start I always had two issues.
1:) Xbox connection dropping when IPv6 enabled. (GTek10G fixed that.
2:) all firmwares above the first one dropped internet for all devices once a day where I had to reset the router daily.
Original firmware was the only working one with GTek10G.
Now with newest version I only have to restart daily now. I'll test out each firmware for a week to see if it is consistent and will update yall after my trials.
