DOGGAVELI
Apr 27, 2019Star
XR700 Lag Spikes
Hi All,
I recently just got Fibre optic cable internet (NBN FTTC) 100 mbs download and 40 mbs upload. I have the QOS set at 70/70 with my Xbox one X 20/20 in device priortiaztion. I play Pubg, Cod WW2, Black Ops 4 and Halo 5 and during these games I get regular lag spikes which cause lots of deaths, friends that I game with also say that my party chat cuts in and out during these lag spikes.
Today I decided to disconnect the XR700 and just game with my ISP gateway router and I never had one lag spike. Once I reconnected the XR700 the lag spikes began. I seen the below in the froum and wondered is this could resolve my issues?
"That's a huge Geo-Filter range, put that to 1000km to make it tighter and get a closer server. Okay strange, toggle SIP ALG in WAN Settings as well, that may help with chat with QoS on and in Internet Setup change the connection to static rather than dynamic. Then make sure you've put the speeds you've paid for in Anti-Bufferbloats settings, set to Always and put the sliders to 70% for download & upload. Do a wired PC speed test, do you get the expected results? If so don't worry about the console test for now, see if you get the disconnects/lag spikes and auditory issues."
My nbn connection is also ppoe so I'm not sure whether that would cause any issues. Appreciate any help and advice.
Kind Regards,
Dogga
- AltsaiNETGEAR Expert
there are many factors will cause such lag, so I suggestion you provide more info so that Netduma support team can provide some guidance to you
- Netduma_JackNetDuma Partner
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
DOGGAVELI wrote:
Hi All,
Kind Regards,
Dogga
