martyr444
Jan 27, 2021Apprentice
XR700 last 2 Firmware the Scheduled Services not working
The last 2 Firmwares have the Schedule under Content Filtering not working. I have the same start and end time for it to block all services. Now to get it to work, each time I have to go to the Sched...
Netduma-Fraser
Jan 28, 2021NetDuma Partner
That's down to NG, I'll send them a reminder email on this. You can use the Traffic Controller feature on the beta as it is better in my opinion and it works.
- martyr444Jan 28, 2021Apprentice
Hello, I know the Dumos Beta Traffice Controller works, but it's 2 Security Firmwares behind. I have 2 of these Routers so I need Netgear to figure our what they did with the 1.0.1.36 Firmware that broke the Scheduling to where I have to manually go to the Schedule each time to hit apply to get it working. It's still broken with 1.0.1.38. This should be a easy fix even with just a patch. I spent too much Money on 2 of these to not work as advertised.
- Netduma-FraserJan 28, 2021NetDuma PartnerI've sent them an email about this so will get back to you once I have any new information.
Thanks, with your help hopefully a permanent fix soon!
