martyr444
Jan 27, 2021Apprentice
XR700 last 2 Firmware the Scheduled Services not working
The last 2 Firmwares have the Schedule under Content Filtering not working. I have the same start and end time for it to block all services. Now to get it to work, each time I have to go to the Sched...
martyr444
Jan 28, 2021Apprentice
Hello, I know the Dumos Beta Traffice Controller works, but it's 2 Security Firmwares behind. I have 2 of these Routers so I need Netgear to figure our what they did with the 1.0.1.36 Firmware that broke the Scheduling to where I have to manually go to the Schedule each time to hit apply to get it working. It's still broken with 1.0.1.38. This should be a easy fix even with just a patch. I spent too much Money on 2 of these to not work as advertised.
Netduma-Fraser
Jan 28, 2021NetDuma Partner
I've sent them an email about this so will get back to you once I have any new information.
- martyr444Jan 28, 2021Apprentice
Thanks, with your help hopefully a permanent fix soon!
- martyr444Feb 04, 2021Apprentice
Any news from Netgear on a fix for this?
- Netduma-FraserFeb 04, 2021NetDuma PartnerNothing yet but I know they're working on a new update so that may fix it.
Can you find out if they are including a fix for this issue I have been having since the previous Firmware update? If they make another Security Firmware update again that is great and needed, but if it doesn't include a fix for my ongoing issue it won't help with the broken feature. Again, if I hit apply on the time schedule it will trigger it to work. The issue is I have to do this each night after 9PM manually. This all broke with the 1.0.1.36 Firmware update and didn't get fixed with the latest 1.0.1.38.
Start Blocking Hour 21 Minute 0 End Blocking Hour 7 Minute 0
