matt57017
Jan 16, 2019Initiate
XR700 Latest Firmware 1.0.1.8 causing massive issue
The latest firmware update is causing wifi devices to not automatically reconnect, or if they do, they immediately drop. It is so bad, it is causing me to rollback to the previous version which works ...
Netduma-Fraser
Jan 16, 2019NetDuma Partner
So wired devices never lose connection at all? Is it all WiFi devices? Do you have smart connect enabled?
matt57017
Jan 17, 2019Initiate
All WIFI devices. Some stay connected, others bounce.
I rolled back to the previous version, and everything went back to normal
