Nokum87
Dec 07, 2020Follower
XR700 led issue
Hi all, I bought a second hand xr700 last week and thought I would seek help here before I go for a refund. The issue I have is that the left hand side of the led light strip doesn’t seem to work ...
Netduma-Fraser
Dec 07, 2020NetDuma Partner
If it's not disabled via the switch/on the interface then it is most likely just a faulty LED as the router is obviously on so if that is a problem then do pursue the refund.
