Talontedd
Oct 28, 2018Apprentice
XR700 Log - Issues?
Anyone know what these items caught in log. I have notice every so often internet connection will hand for second or two. Any expert advice - ok or not ok?
Bunch of these
[DumaOS] No w...
- Oct 28, 2018
I found the fix for this issue and that is to turn ipv6 on. I have supplied a screen showing the settings I have used. Once you do this all ARP TABLE issues will go it seem there's a bug with firmware around ipv6. I have found this also fixes the issues around the wan connect dropping.
Talontedd
To clarify turn on or turn off IPv6?
XSvirusSAFE
Oct 28, 2018Star
Turn on as I have done within the photo.
- TalonteddOct 28, 2018Apprentice
Did as you suggested will watch for period to see if logs cleanup some.
- XSvirusSAFEOct 29, 2018StarAfter you made the following system changes has it been stable? Also have you experienced any connection drops?
- TalonteddOct 29, 2018Apprentice
Since making change, turning on ipv6, no more errors seen, link has been stable. Will monitor over next few days during gaming sessions.
Thanks for help.
