Talontedd
Oct 28, 2018Apprentice
XR700 Log - Issues?
Anyone know what these items caught in log. I have notice every so often internet connection will hand for second or two. Any expert advice - ok or not ok?
Bunch of these
[DumaOS] No w...
- Oct 28, 2018
I found the fix for this issue and that is to turn ipv6 on. I have supplied a screen showing the settings I have used. Once you do this all ARP TABLE issues will go it seem there's a bug with firmware around ipv6. I have found this also fixes the issues around the wan connect dropping.
Netduma_Jack
Nov 15, 2018NetDuma Partner
Hi everyone,
I just got wind of this thread. So I've got a response from the developers:
"The log panel should be ignored by customers. Since it is causing support issues we will probably remove it in future versions. Every message in this thread in benign. The "warnings" and "errors" are simply letting the developers know that we are getting unexpected parse lines (which is very normal!). They have absolutely no impact on the routers performance. In fact this section is about detecting when a device goes offline and has nothing to do with Internet traffic / performance / disconnects, IPv6, etc -Iain "
Altsai
Nov 21, 2018NETGEAR Expert
Got beta FW which can fix the issue. Suggest you can contact NTGR team for the beta FW.
- Jrac86Dec 08, 2018AspirantWhat version of beta firmware did you get? Can you share it? I opened a support ticket with Netgear for some issues I was having and requested any beta firmware, but they have not responded and it's almost been a week.
- TalonteddDec 08, 2018Apprentice
I am not using beta. I am using the previous version. This has performed well while waitimg on nexr firmware version release.
- Netduma_JackDec 11, 2018NetDuma Partner
Do you have a Case ID Jrac86 ? We can chase this up for you with NETGEAR.
