Tou
Apr 08, 2020Aspirant
XR700 looses configuration after power down
Every power failure from the electricy network causes router to loose it's configuration.
I have two different routers and behave exactly the same. HW or SW bug?
- Netduma-FraserNetDuma PartnerMight be that the power surges before going out. Do you have them connected to surge protectors?
- TouAspirant
It is observed and repeatable even if I have it on APC UPS and turn UPS off by power button.
Router has bad electrical design or config refresh in memory. The flash memory shall not be broken by power down in any router or modem. It wasn't in any flash device I owned from 2002.
- Netduma-FraserNetDuma PartnerRe-flash the same firmware and then do a factory reset just in case it was corrupted during a previous update.
