GT46
Apr 28, 2021Aspirant
XR700 losing internet, restart fixes it
I have an XR700 running firmware 1.01.34. I realize this isn't the latest firmware but when I upgraded to 1.01.38 I had a bunch of connectivity issues with many devices. I tried disabling smart con...
GT46
The modem I am running connected to the XR700 is Hitron Technologies EN2551 supplied by Spectrum. It was upgraded wthin the last year when I upgraded to the XR700. My service is 400MB service and they suggested this one being better.
The fix that NG is looking at is for the recent firmware update or the problem I am having with the old firmware?
Also, one more follow up question to your suggestion, are you suggesting I load the latest firmware and perform the action of changing the range of pool from 192.168.1.2 -192.168.1.50 or trying this on the firmware I currently have loaded?
I saw that as a fix for the new firmware but some users said it would be lost when they reset or restarted. Seems like a lot of work for something that I might have to do again but if it made my problems go away I would try it.
Netduma-Fraser
Apr 28, 2021NetDuma Partner
Sorry I mean changing the pool to 192.168.1.50-192.168.1.254 and applying the reserved IPs using .2 - .49 so the addresses we've made available outside the pool.
Regarding the disconnects specifically I was referring to, you don't need to upgrade the firmware to change the pool/IPs so can do this on your current version. If you factory reset they would disappear yes but hopefully by the time the next firmware version is available the issue will be resolved and you can reset as they won't be needed.
