user12a
Sep 13, 2023Star
XR700 lost WiFi after FW upgrade to R700-V1.0.1.50-0626 from NetDuma
After upgrading to the latest V1.01.1.50-0626 bin, I lost all the WiFi and could not turn them back on.
I have tried simple reset, factory reset, downgrading to an older bin, and reloading bin ...
Netduma-Fraser
Sep 14, 2023NetDuma Partner
I've responded to you in the topic, just so you know we primarily respond here as well so you may not get any further answers unfortunately - it is also a community forum so you won't get an official Netgear employee commenting.
Sep 14, 2023Guru - Experienced User
And by the looks of it most troublshooting has been exhausted.
You'll need to contact NG support to see if they will help any.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
I can only tell you that if it's out of warranty, your problaby out of luck as well.
I recommend if you want keep using the XR700, do as the other user suggested and disable the radios on the router and install something better. I've use a Orbi and MK MESH systems in AP mode connected to my XR700 when I had it online. Works great.
Good Luck.
