user12a
Sep 13, 2023Star
XR700 lost WiFi after FW upgrade to R700-V1.0.1.50-0626 from NetDuma
After upgrading to the latest V1.01.1.50-0626 bin, I lost all the WiFi and could not turn them back on.
I have tried simple reset, factory reset, downgrading to an older bin, and reloading bin ...
Dec 02, 2023Guru - Experienced User
Something to try and see if this recovers the wifi radios:
https://forum.netduma.com/topic/51612-new-xr700-beta-firmware-33363/?do=findComment&comment=385598
I have tried simple reset, factory reset, downgrading to an older bin, and reloading bin through TFTP, toggling wifi off/on switch at the advanced wireless setting, tried the wireless on/off button. None worked to bring WiFi back.
The 2.4/5/60 wifi lights immediately turn on after power button is pushed on, with the 2.4/5 lights dimmer at about 50% intensity. They stay same throughout and the antenna red lights turn on after booting. The WiFi lights coming immediately on is abnormal. System Info tells all WiFi are disabled.
I have spent some time but could not get the WiFi to come back on.
Does anyone have any ideas?Thx.
https://forum.netduma.com/topic/51612-new-xr700-beta-firmware-33363/?do=findComment&comment=378963
