ShadowMelt
Nov 11, 2020Apprentice
XR700: not getting isp speeds on wifi
Hello, I'm having issues with wifi speeds on the router. My isp upgraded my modem to an gb modem. After the change I tested it out with the tech. I was getting the speeds wired but wireless im getting...
Netduma-Fraser
Nov 11, 2020NetDuma Partner
What devices are you testing the wireless on? Are they capable of higher than 450Mbps? Have you got faster than that on the WiFi before?
ShadowMelt
I have been looking to see if the devices I been testing on are able to but can't find specs been using Note 20 ultra which on 5g WB I can get 1.2gps. The laptops and other stuff I'm not sure. Xbox and ps4 are only able to download around 100mb
- Netduma-FraserNov 12, 2020NetDuma PartnerIn Advanced WiFi settings enable MU-MIMO, Beam forming and HT160 and see if that improves speeds on the Note.
- ShadowMeltNov 22, 2020ApprenticeIts improved very very slightly but gets to speed differently before it would start off at 400 to 450 but but now with these settings turned on it starts at 100 and works to 500 to 550. Is there anything I can do to get my speeds?
- Netduma-FraserNov 22, 2020NetDuma PartnerSo you're getting your speeds its just not getting there as fast? I don't think there is anything you could change that would affect that other that selecting a different speedtest server.
