ShadowMelt
Nov 11, 2020Apprentice
XR700: not getting isp speeds on wifi
Hello, I'm having issues with wifi speeds on the router. My isp upgraded my modem to an gb modem. After the change I tested it out with the tech. I was getting the speeds wired but wireless im getting...
Netduma-Fraser
Nov 22, 2020NetDuma Partner
So you're getting your speeds its just not getting there as fast? I don't think there is anything you could change that would affect that other that selecting a different speedtest server.
ShadowMelt
Nov 22, 2020Apprentice
I have been doing multiple speed test, wired connection varies from 850 to 950 even the modem speed test reads it at 922. Wifi i just can't get 5ghz to stay even above 500 most of the time.
- Netduma-FraserNov 22, 2020NetDuma PartnerDo you have many electrical devices in close proximity to the router? Is there another WiFi you're broadcasting? Are ALL devices connected to the XR?
- ShadowMeltFeb 03, 2021ApprenticeYes I moved stuff around at first close to the monitor of the computer but now it further away. Attached is wifi channels and I'm the red hoping it's not others wifi ruining my experience
- Netduma-LiamFeb 03, 2021NetDuma Partner
OK, did you see any difference in the results after that?
Are all devices connected to the XR?
