Link8900
Nov 28, 2018Tutor
XR700 or AX8?
Time to upgrade my router since my ISP just got 1gb Internet. I cannot decide between the XR700 or AX8? The XR for gaming purposes or the AX for WIFI 6? Any opinions?
- Nov 28, 2018
I would give wifi 6 a few years. No rush in doing anything with AX. It took AC several years to be come the norm and get into consumer devices. It's still not THEE norm. There still plenty of N and AC devices out there now and there still being used. 160Mhz hasn't really kicked off either. You'll be fine with the XR. If later on down the road you want new WIFI 6, and theres clients to support it, you could just add WIFI 6 to the XR as a external wifi AP.
Nov 28, 2018Guru - Experienced User
Link8900
Nov 28, 2018Tutor
Thanks a lot for the info. definitely good points. I'll get the XR!
