Talontedd
Jan 10, 2019Apprentice
XR700 Periodic WAN disconnects (still) on latest v1.0.1.8
Here to report same issue occurring for me with v1.0.1.2 and v1.0.1.8 firmwares. Both exhibit periodic dropping of WAN side connection, typically every 5-10mins. No lights change color, from outsid...
Talontedd
Feb 09, 2019Apprentice
I would recommend you try these options...
1. Use firmware v1.0.0.20 (this gave me stable WAN with only firmware load no resets required)
2. Load v1.0.1.8, reboot, admin factory erase, reboot & power off (wait 15), power on then hard reset followed by power off (wait 15), power on and setup new config (this resolved my WAN stability issue with newer firmwares but only after erase, power off and hard reset sequence was included)
3. Use SFP+ port module vs native ethernet WAN port (this gave me stable WAN too - I tried it because others said it worked)
4. Start a netgear case# (not here but with official product support) and have them walk through various sequences
KyleK
Feb 18, 2019Star
Over two weeks later. Still no update nor any kind of acknowledgement from Netgearđ
- YonijoFeb 18, 2019TutorHello
NETGEAR send me a beta firmware ans for the moment everything is ok. Finger cross !
And for information i don t have sfp adapter
Regards - KyleKFeb 18, 2019Star
Thanks, good to know but they need to release it to the general public already.
- PastorJohnFeb 18, 2019AspirantHey lately I've been getting a message when I start up dumaos "The R-app is not loaded yet, please try again in a minute."
Trouble is everytime I reload I get the same error... What the heck is this now? - Netduma_JackFeb 19, 2019NetDuma Partner
That happens when something in the router is taking more than 30 seconds to start. In general, you don't need to worry about it, especially if you have just rebooted the router (wait 30 seconds and everything should be good to go)
- PastorJohnFeb 19, 2019AspirantTrouble is it never resets... it's happened the last few times I've started up dumasos... and it essentially never stops spinning. Any other suggestions?
- Netduma-FraserFeb 19, 2019NetDuma PartnerTry in an incognito browser, does it still not load then?
