gfhartzell
Aug 18, 2022Star
XR700 Plex update
When should we expect a firmware update for the PLEX server?
gfhartzell
Sep 10, 2022Star
now i am getting an error message that server version Required is 1.24.4 or higher for live TV.
any way to nudge netgear? or how to contact someone at netgear about this recurring issue?
last update was version 1.22.3.4392 dated April 19, 2021
Thank you
gary
Sep 10, 2022Guru - Experienced User
You might reach out to NG support.
- gfhartzellSep 09, 2022Star
My Netgear Nightawk XR700 requires an update to Plex Server version for live tv.
Current Version 1.22.3.4392 Minimum Required is 1.24.4 or higher.
when will there be a firmware update for the plex server?
Thank you for your assistance.
ps
Current Plex version: 1.22.3.4392-d7c624def Apr 19, 2021 Your Plex Media Server version is up to date. - michaelkenwardSep 10, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.- gfhartzellSep 10, 2022StarThank you for the move request
This is a recurring issue over the years with no obvious path to even contact Netgear
For the required update unfortunately
- Netduma-FraserSep 11, 2022NetDuma PartnerI'd recommend making a ticket with Netgear directly https://my.netgear.com/support/contact.aspx meanwhile I'll see if we can ask someone at Netgear to see if they can get this sorted
- gfhartzellSep 11, 2022Star
I placed a ticket after several attempts going in circles I finally was able to get a ticket by leaving out my serial number. hopefully one or both approaches will get a response,
thank you
Gary
