Jingaker
Mar 19, 2019Guide
XR700 Problems with MedieServer (Firmware V1.0.1.10)
Hi,
Just got my new Router and it´s works great except the medieserver thats can´t show
the media at my LG-tv in a proper way.
When you use browse folder you got both folders and mediefiles at ...
Mar 19, 2019Guru - Experienced User
Are there any ReadyShare features with in the XR menus? Check to see if any are available and enabled...
Netduma-Fraser
Mar 19, 2019NetDuma Partner
Have you configured ReadyShare correctly on the router? Did you use this prior to the update?
- JingakerMar 19, 2019Guide
I hope so, attach a picture of the configuration. I have not used ReadyShare before because I had an Asus router before.
- Netduma-FraserMar 19, 2019NetDuma PartnerCan't see the picture as it hasn't been moderated yet. Can you upload to a service and link to the image?
- AltsaiMar 21, 2019NETGEAR Expert
did you also enable SMB 1.0?
are you able to find the files via SAMBA protocol? e.g., \\jingmedia?
