Jay305
Jan 02, 2020Follower
XR700 R-app not loading.
R-apps are still not loading 1/2/2020. This is unacceptable!!! This router cost too much money for NG to be with this bs. I've tried everything you can do to this router to fix the issue and nothing...
Netduma_Alex
Jan 02, 2020NetDuma Partner
I'm sorry it's taken so long, but the developers think we're quite close to a solution to this issue. It won't be long now.
Boulou
Jan 19, 2020Aspirant
I have the same problem.
No solutions yet ?
- Netduma_AlexJan 20, 2020NetDuma Partner
If you have a Nintendo Switch, go to Device Manager and change your Switch's device type to Xbox or PlayStation.
- jhyltonJan 21, 2020Tutor
I'm having this same problem. WTF good is a GAMING ROUTER if you can't set the MF up the the first place. I can't access QoS or Device Manager. Then, I find out if I want to call you people, I have to PAY to do so. This is ridiculous..... FIX IT!!
- Netduma-FraserJan 22, 2020NetDuma PartnerHave you tried some of the other solutions such as seeing whether it occurs on other browsers or changing the retry amount from 3 to 5 in the R-App panel options on System Information?
