Jay305
Jan 02, 2020Follower
XR700 R-app not loading.
R-apps are still not loading 1/2/2020. This is unacceptable!!! This router cost too much money for NG to be with this bs. I've tried everything you can do to this router to fix the issue and nothing...
Netduma_Alex
Jan 23, 2020NetDuma Partner
To anybody experiencing this problem: Send me a private message and I will give you a link to a new hotfix firmware that should fix the R-App not loading issue.
one50six
Apr 19, 2020Aspirant
R-Apps not loading. Netgear tech support told me to: 1. upgrad firmware, did not work. 2. hard reset the router, did not work either.
- Netduma-FraserApr 21, 2020NetDuma PartnerHave you tried upgrading to this firmware? https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix You'll also need to do a factory reset afterwards to ensure no legacy issues carry over from the previous firmware.
